Little advice
Old Nov 11, 2019 | 07:54 PM
Bspeck82's Avatar
My advice is I strongly recommend buying a good tire for the rear, like an nt05r or street ss MT and put a circle d 3600 converter in it it will drive well and I'd wager the first time you hit it off the line it will scare you. Then work on suspension. Does it have stock computer and obd2? Grab hptuners, if its carb I would save up and buy an edelbrock pro flo efi system and a tci trans control module. If it's an 89 you should need to go through a sniffer. Keep that in mind.
Dont run SD go with a maf. Also Read up on local emmissions laws and see what's required to pass.
With all that room I'd be tempted to forget about the 60e and save up for an 80e with a decent converter.
Old Nov 11, 2019 | 10:19 PM
BigBurd89's Avatar
i can’t keep the 3600 for the 80e? And ok you guys seem to be swaying me in a diff direction maybe I was just trippin about needing all that stuff but I’d still like a good lopey cam you know? And it’s truck intake I plan on putting this intake on it https://www.ebay.com/i/263683857247?chn=ps&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=263683857247&targetid=59377238801 3&device=m&mktype=pla&googleloc=9059566&poi=&campa ignid=2086088343&mkgroupid=77258593596&rlsatarget= pla-593772388013&abcId=1141016&merchantid=119098165&gc lid=CjwKCAiAh5_uBRA5EiwASW3IaqydAYjAV82_Zc9DT2qPgi tBF6lZsejyy6mqZDkoMXUIbh56NROjghoC724QAvD_BwE
Old Nov 11, 2019 | 10:20 PM
BigBurd89's Avatar
Originally Posted by drdave88
It sounds like you have read some of the "hot words" on modifying an engine and are running with them without really realizing what it is you'd even be doing. That's nothing against you, but do you know why you would need to change your rockers, or pushrod length? What would make speed density better than MAF? I'm with bammax, learn the basics and build up from there. If you don't fully understand what you're working on, you won't be able to make it run right.
your good bro. And your right tbh but mostly jus what I figured is so it could take the abuse and power and thought if I kept it stock I’d have to get a new engine
Old Nov 11, 2019 | 10:22 PM
BigBurd89's Avatar
Originally Posted by Kjduvall
​​​​​Pretty Shure this is what you were talking about when you mentioned leaf springs. YOU don't have em, it's a third gen. It's very similar to a 4th gen you have a torq arm set up. You want to build rear suspension call umi or bmr and talk to em thell set you straight. Engine/ stall set up go with a tried and true combo (research for many hours) but my quick,fast,off the top ove my head would be tsp kit pushrods/springs/cam kit. In something like a 228/232 on 111+3 or a good ole 228/228 and a yank SS 3600,a real Dyno tune by some one that knows there ****, and do your self a favor research alot more so you can make better decisions on parts purchases. Or break down your questions into smaller groups, and post them in threads here like, suspension/trans/gen 3 internal/etc...... Good luck and post a pic of it we'd like to see it .
im not sure it’s just what my dad told me but he’s always worked with trucks and an s10 blazer above 90’s and for sure man I’ll look into stuff better
Old Nov 12, 2019 | 08:11 AM
Bspeck82's Avatar
Trail blazer nbss is a great truck intake. I saw one on ebay with rails injectors and TB for like 300-400 bucks. For a good lopey cam call ws6store and order up the hot cam. Good bang for buck too. Keep the 60e will likely not break it. Throw in the circled 278mm converter, 3.23 gear minimum 3.73 max and longtubes with true duals. All that should net 380whp-ish and run high 11s. This is what I'd do in your situation.
Old Nov 12, 2019 | 10:39 AM
BigBurd89's Avatar
ive been wondering what kind of exhaust system to put on it a friend recommended flowmasters and headers I have to choose wisely cause another friend I better hope it isn’t too low or I’d have to have them custom made
Old Nov 12, 2019 | 10:41 AM
BigBurd89's Avatar
Ok tho I’ll go easy on the car start with basics be one with the car but y’all can throw me ideas and I’ll screenshot them and save them for later
Old Nov 12, 2019 | 10:53 AM
ddnspider's Avatar
Flowmasters suck. Dynomax, magnaflow, hooker ftw.
Old Nov 12, 2019 | 01:57 PM
Bspeck82's Avatar
Spintech, maxflow, aerochamber are my favs. Flowmaster 10s sound good but everyone has them. Dynomax super turbo if you want to keep it real quiet.
Old Nov 13, 2019 | 09:57 AM
cookseyb's Avatar
Corsa and be done with it..Amazon has several good books on these engines and things you need for swaping them in various vehicles, study them, make a plan, and then you won't have bought a bunch of junk promoted by the internet.. Good Luck, Keep us up to speed as you go and quit listening to you buddies bench race.
Old Nov 13, 2019 | 10:35 AM
Bspeck82's Avatar
There are other kits that sound better and look just as good at a fraction of the cost. Tsp rumbler for example
Old Nov 13, 2019 | 04:37 PM
  #32
Kjduvall's Avatar
Headers/true dual / my favorite muffler that gets no credit but is awesome sounding /not restricted/stainless/and budget minded........... GIBSON MWA 3in /out straight through.
Old Nov 13, 2019 | 10:22 PM
  #33
BigBurd89's Avatar
would you know how to make the rear end heavier? And not tryna jump any guns but put a posi in it? Or limited slip?
Old Nov 14, 2019 | 07:07 AM
  #34
JoeNova's Avatar
Restricted User
Nope.
Old Nov 14, 2019 | 08:13 AM
  #35
drdave88's Avatar
Why do you want to add weight to the rear, traction? Weight isn't the way to go, tires and limited slip diff are.
Old Nov 14, 2019 | 10:57 AM
  #36
BigBurd89's Avatar
Cause it’s heavier in the front than the back? Figured it’d keep it planted and won’t spin out as much
Old Nov 14, 2019 | 10:59 AM
  #37
BigBurd89's Avatar
Originally Posted by JoeNova
Nope.
why so? I wasn’t gonna buy that from eBay I was getting it from summit or JEGS. I’m not into the high rise intakes and I also want to keep the hood on it
Old Nov 14, 2019 | 11:04 AM
  #38
drdave88's Avatar
Take weight off the front then, don't add weight to the back. Get good tires and set your suspension up right to reduce spin. Don't just dump weight in the back, sounds like some backwoods hillbilly stuff lol
Old Nov 14, 2019 | 11:26 AM
  #39
BigBurd89's Avatar
Hehe yea kinda but the only thing I could think of to take weight out is the engine 😂 it’s the iron block and maybe set the suspension where fronts higher than the back? Was also gonna throw the Mickey Thompson’s on there mention earlier by someone. Also wanted to know if I should make the front tires jus a little wider I don’t want it to look all wonky. What do you think?
Old Nov 14, 2019 | 05:48 PM
  #40
cookseyb's Avatar
To each his own. The Corsa fits my American Racing Long Tube headers perfect and no drone...
