torque converter
torque converter
I am looking at a recommendation for torque converter. Below are the specs. The bottom end of the 6.0L is factory.
Do you know how much HP this will produce?
Ford 9" 373 gears
It is a 1951 Ford but it has a tube chassis My best guess is 3,500 lbs
20" wheel with a 4 inch side wall
Brian Tooley Racing .660" Lift Platinum Spring Kit for all LSx Engines
(Retainer Type: Light Weight Tool Steel Retainers, Locator Type: .505" Locators for Stock Guides, LS7 Application? No) SK001
Comp Cams Hi-Tech Length Checking Pushrod 7702-1
Comp Cams LS Rocker Arm Trunion Upgrade 13702-KIT
GM Cam-Swap Gasket & Bolt Kit CUSTOM
GM Timing Chain for 1997-2014 LS Series Engines (Also fits 2014 LT Engine) 12646386
Tick Performance Blueprinted & Ported GM Standard Volume Oil Pump for LS1, LS6, LS2, and LS3 Engines 32586665
Tick Performance CUSTOM Camshaft for All LSx Engines TPMSCC
Ford 9" 373 gears
