Question: Crank Timing Gear Install
Hello,
When installing the timing gear on the crank, how far on does it go? Does it bottom out or is there a clearance I need to measure behind it with a feeler gauge?
I've been searching all over and can't seem to find an answer, everything I find just says to push it on but not how far.
I used my old crankshaft timing gear to hammer the new one on. You could hear a definite change in the sound of me hammering it on when the new timing gear bottomed out. Instead of using a hammer you can also use your old crank sprocket and the old crank bolt. The crank bolt's head should be wide enough to press the new crank on evenly and smoothly.
