Having a random disconnection issue with all my ignition, starter and 3 fan relays. This is on a 2000 Formula WS6. Occasionally any of the systems mentioned will stop working and its always the relay connection in the fuse box. The fix is always the same, pull wires, re-bend/tighten the connection and plug everything back in. Also had to replace the relays a couple times because the connection gets loose and creates a lot of heat. I picked up a stock fuse box cut out of another car but can see and measure no difference between the two. Any idea's for a different fuse box design? I might just make one after driving home like the photo below the other night after the connection stranded me again.
