Hard Start Issue
If I crank and hold the switch the motor struggles to turn over, its like its seized (its not). I let the switch go and try again its better and it starts. What possible could be the problem?
it was the ground cable from the battery fixed that ….
Now when it starts runs for couple seconds and dies out have to start a couple times before it stays running.
Any idea what might be the issue??
TIA
TIA
Have you tested the battery to make sure it is delivering 12 volts? Modern PCM's are sensitive to voltage and can act weird when they battery has a low charge.
I tired no luck....when turning the key forward I hear the fuel pump. It cycles and stop crank doesn't start cycle again....
what I did realize is when it start running I hear the throttle body sucking air. Other times I don't
