2002 Camaro Break lines
I just bought a roller z28 with tubular front end car is in real nice shape but they removed all the break lines i plan on making around 1000rwhp turbo set up witch break set up would everyone recommend
If all the lines have been removed from the k-member and from the car down to the rear then you'll have to make new ones. Local parts stores will have the 3/16 inverted flare lines and the unions. This was what I had to do when I installed the line lock and bypass the ABS block.
