Stock 243’s or Ported?
Intake, no. Throttle body, yes.
And you are way oversprung with those valve springs and that camshaft. I would get a spring that is rated to .600 so it is closer to coil bind at full lift.
The following users liked this post:
RocketBird (01-16-2022)
If you're going to do a significant head upgrade then you'll want to grab a better intake such as a fast 90/92/102... or you can send off your intake to TPIS and they will put a 90mm snout on it, which is on par with a fast 90. Then you'll be getting a throttle body with the same opening your intake is.
my tuner said I’ll be fine with my setup, beside i wanted a really aggressive duration for the cam & 660 lift.
Tyler Dietzenbach (01-17-2022)
Quite a few posts about them taking literally months to return heads sent to them for work.
And thats not to mention being unable to get anyone to return e-mail's, calls, txt's, you name it.
