4.8 Very Hard Starting!!!!
So I’m having this frustrating hard start issue. I’ve researched for days with no luck, here’s the issue.
swapped a gen 3 4.8 into my 70 c10, hasn’t been driving yet but has been started about 30 times just idling. Been running amazing, starting very well, over the past month…. It’s been getting harder to start, long cranks, finally one day I got it running, then it stalled on me and I couldn’t get it running again. Un hooked battery for a couple days and now it will start but it’s extremely hard, takes 30 seconds or more of cranking. I’ve changed plugs, checked iac ohms, no cel’s. Cannot figure this out.
4.8
Aeromotive 355 pump
58psi verified with 2 gauges on my setup
stage 2 Texas speed cam
ls1 injectors
vats removed with base tune
4.8
Aeromotive 355 pump
ls1 injectors
Ok this is gonna sound stupid, but how much gas is in the tank? What is the condition of the tank itself? Hows the sock on the in tank pump? Checked the fuel filter? There was a LS swap thread that was like a year of a guy messing with things before he realized there wasn't enough fuel in the tank.
A lifter wouldn't keep it from starting and running. Start checking the easy stuff 1st. Fuel, spark, and spark at the right time, compression. Maybe the fuse to the fuel pump blew.? Do you hear the fuel pump run when you turn the key to the on position?
When you said you have spark... is that because it will run sometimes? Or have you checked spark while the engine is cranking and has not started yet? Make sure there is spark while cranking.
Without knowing how the harness was run and powered it's hard to say. Did you check all fuses for circuits powered during the key cranking position? Not the run position.
