I swapped my ls1 to a 5.3 cause I blew a hole threw it but after riding around cruising the 5.3 for a couple months it started losing oil pressure after using it for 15 to 20 min it’s starts at 40 psi but keeps losing pressure after riding a bit I honestly think it’s the oil pump but don’t really know any clue to what it might be? I plan on putting a cam in it later so I’ll replace it with a performance oil pump then. 40psi at start up Starts losing pressure after riding15-20min
If you do replace the oil pump purchase it from this sites sponser Summit Racing and get the Summit brand p/n SUM-121170
It is actually a Melling pump 295 standard pressure/volume. If you want more pressure install a washer at the pressure relief spring. Works great for about $80 less than the Branded Melling pump
