Launching on a 10-bolt
I watched a 98 GT scatter an 8.8 on the starting line last night and he was running a whopping 14.0@100 with slicks.
I've seen people run 140+ mph traps hold up fine with 8.8's, so I have no idea how a car with 1/3 of the power could blow it up.
i did my first hard launch yesterday. from the looks of it i blew up my ring/pinion. had it towed. end of story. you take a gamble when launching with on these rear ends. this was my 1st and last floored launch. Never again!!
J
J
how much would you say your car weighs...with your in it? The heavier the car the more chance there is you will break parts. I have put some serious abuse on my car in the last 3 years and SO FAR the rear is still intack, the only thing that has changes is gears. I dont have a TA cover or any other parts to make it stronger. As you can see from my sig I have done many 1.5 and now some high 1.4 60' with the stock rear. My 4400 stall liked to be lauched around 2500 rpms when the car was just bolt-ons, but now with the added power I plan to try a little higher and see how it does.
With your stall just try different rpms. Yes, foot on the brake hard and then then put your foot on the gas just to the desired rpms. start off with just above idle, then around 1500, and then go up a little at a time. With a 4000 stall I would say around 2k rpms but all stalls are different.
i took out the back seat, spare tire/jack. and im about 170. it cant be that heavy. i launched froma almost a dead stop and just floored it, but i think that bad thing is i hooked really hard and "boom!"
J
J
Originally Posted by z98
Details please.
![Bomb](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_bomb.gif)
