Low reference wires on E38
Old Oct 27, 2023 | 09:41 PM
MattBriz's Avatar
Default Low reference wires on E38
Hello, new to forum. I don't have a F body......but have 08 Silverado and 11 Suburban. Both are 5.3. I'm having O2 sensor issues with the suburban. Keeps saying stuck lean or insufficient switching. I find hard to believe new Bosch sensors are bad. I have run new chassis grounds firewall to head to head to block to frame back to firewall. Even new ground from PCM ground wire to block. Still having issues. Saw a post here thru a search that I now can't find. It was about tieing all the low reference wires together.......but where do I run them to if I do this? Low reference wires are basically sensor grounds aren't they? I have new O2 sensors on order just in case. Thanks for help. Matt.
Old Oct 30, 2023 | 06:26 PM
jetech's Avatar
Veteran: Air Force
My experience is always use ntk/ngk or Denso instead of Bosch on a GM vehicle. Same with spark plugs. Video
History...? Were the only dtc's you received p1133 and p1153 ? Before and after the sensor replacements?
Old Apr 20, 2024 | 06:52 PM
stealth355tpi's Avatar
Any luck with your p1133 code? I'm trying to fix the same problem.
Old Apr 20, 2024 | 09:10 PM
jetech's Avatar
Veteran: Air Force
Make sure there are not any vacuum or exhaust leaks?
Old Apr 21, 2024 | 06:52 AM
No vacuum leaks. Going to try the exhaust next. When the code sets, it's showing lean and trying to add fuel.
Old Apr 21, 2024 | 07:03 AM
jetech's Avatar
Veteran: Air Force
I suggest checking fuel pressure also
Old Apr 21, 2024 | 09:11 AM
Well I've got exhaust leaks but very small ones at connection points further down the exhaust. But the y-pipe connection to the driver side header has no leaks which is the side I'm throwing the code for, p1133. No fuel pressure issues either, I have a gauge for that in the car.
Old Apr 21, 2024 | 12:20 PM
jetech's Avatar
Veteran: Air Force
Did this issue start after some maintenance or some upgrades? Tell us about your vehicle
Old Apr 21, 2024 | 06:20 PM
Car got a cam change and procharger 12 years ago along with a new tune, that was the last time it got any mods. Before that I put in new up stream denso 02's. No codes until last summer it started to throw a p1133 code here and there. By late summer/fall time it started to happen more and more. Now that the weather is nice here and I'm starting to drive the car again, I'm still getting the same code. The last 2 times I pulled the code it's showing it was lean on that side and adding fuel when the code set. Just put in 2 new denso 02's and still getting the code.
Old Apr 21, 2024 | 10:07 PM
jetech's Avatar
Veteran: Air Force
Do you have access to a graphing scanner? It might be able to help with giving direction to the faulty area
Old Apr 22, 2024 | 05:58 AM
I'm working on that next.
