VERY unhappy with aftermarket lid
Originally Posted by tones2SS
Actually, GM HIGH TECH PERFORMANCE ran a test on like 8 different airlids and SLP was the one that fit and was constructed the best. AGAIN, NOT MY OPINION, this is written in GMHTP magazine. Hope this helps you out. GOOD LUCK!!!!!!!!!!
ok, NOW i'll stop bitching.
bowtie4life, no need to shout man! i do agree that for the price you pay you should get a quality unit that fits just like the stocker. and you probably could make a little money if you made a sure-seal gasket kit for bunk lids...
Hey alll... I have a whisper lid, and it fits perfectely. I dont know about other models but mine didnt fit all all until I found out the lip on the front has to go inside the base. BTW, what brand?
Originally Posted by SmokingWS6
Ok I finally made out what was going on in the first pic. That gap is normal, no different than mine but I think the filter still seals up to it. However i don't have a k&n gasket on it as its on my stock lid I've never been able to locate gaskets
SLP blackwing
only one good enough for OEM sales
made of an OEM grade material
might not be the best hp one, but quality blows everything else away.
It will stay on my car, until i put the lid with the outlet on the drivers side for my blower on
Ryan
Ryan
#32
little update for you with carpy fitting lids, i swapped the mti clear airlid for the slp lid.
MUCHO BETTER MANG!! fits tight as prom night.
i still ran a strip of thin weatherstrip on the inside of the lid for peace of mind, i'm sure its sealed up real good. i went ahead and got the smooth bellow as well since i had store credit, that and the lid together made it a pain to get on, but worth it.
btw, i dont mean to come off saying anything bad about the quality of mti clear lids, as i'm pretty sure it was a bunk unit. i also dont mean to come off like a know it all newbie, but i highly suggest that you take the end of a zip tie or the like and see if you can push it easily between the filter and lid underneath the maf neck. that little gap (if you have one) could suck in alot more crud than you think.
#33
From: Central Indiana Honors: 4th grade spelling bee contestant
I had an LS1 Motorsports lid that didn't fit all that great and wasn't as durable as the SLP lid I replaced it with. The SLP lid is sturdier and the fit is great.
The GMHTP article that was referred to earlier on lids really uncovered the good from the bad in several key areas.
#34
Well ... in all humility, my TSP lid has fit great from day one ... just the regular cheapo version ... not a super-carbon-fiber version or clear acrylic or anything like that ... just a basic lid. Works great, I'm happy, what else can I say???
#36
Originally Posted by bowtie4life
MY LID FROM MTI SUCKS *****, IT LOOKS LIKE IT WAS DONE FOR A 4TH GRADE ART PROJECT USING PAPER MASHAE....FOR AS MUCH AS THESE PEOPLE SELL THESE LIDS FOR YOU WOULD THINK COULD INVEST IN A LITTLE R&D AND MAKE THEM FIT BETTER, NOT ONLY DOES MINE NOT FIT, BUT SEVERAL FRIENDS DONT FIT EITHER....NOTHING A LITTLE HOMEMADE FAB COULDNT FIX....GUESS I SHOULD GO INTO BUISINESS SELLING A FITMENT PRODUCT FOR THESE BUNK *** LIDS.
#38
Also I have the K&N air filter, #33-2118, and it came with a rectangular foam gasket with adhesive on one side. I applied it to the underside of the lid and it allowed the lid to make a better seal. But it made the lid a bit harder to close again - but it is sealed. Probably over time that foam gasket will compress a bit.
#40
The most common problem is leaving the gasket out, and not pushing the rear tabs in far enough for the front of the lid to clear the the raised lip in front. If you don't have the gasket call K&N and they'll send you one or frost king r338 (available at home centers) is 3/8 wide 3/16 thick foam that you can make up in about 10 minutes.
The SLP lids generally fit well and flow well, and I have not heard of too many problems with the MTI lids.
