Ls engine
Old Jul 15, 2024 | 07:57 AM
FRRREAK's Avatar
Default Ls engine
How do I figure out exactly what ls engine I have?
Old Jul 15, 2024 | 05:08 PM
the_merv's Avatar
If it's stock and untouched, the numbers on the corners of the Heads narrow it down fast. If it's still in the original vehicle that's even better..
Old Jul 15, 2024 | 08:44 PM
B52bombardier1's Avatar
If you have the original factory Powertrain Control Module (PCM) that was mated and factory married to this motor, you can pull the Vehicle Identification Number and decode it to discover it precisely. HP Tuners or PCM Hammer can do this file pull from the PCM.
Rick
Old Jul 17, 2024 | 06:43 AM
Balded Piston Head's Avatar
Brethren,
New Guy To LS Motors, Old Guy For when they Had Points & Plugs.
But My Question Is : My motor has Cover To Cover My Coil packs ,So Which Side Has the Oil Fill Cap ?
Thx,
Baldy
Old Jul 17, 2024 | 04:11 PM
Gen 3 LS motors have the oil filler cap on the passenger side, front of the head, through the valve cover. The dipstick is midway down the passenger side of the motor. What year is your motor?
Rick
Old Jul 17, 2024 | 04:55 PM
the_merv's Avatar
Originally Posted by Balded Piston Head
Brethren,
Thx,
Baldy
If you're looking at it in the car, front passenger side you'll see the cap on a filler neck in the Valve Cover.
Old Jul 18, 2024 | 05:47 AM
Thumbs up
Brethren,
Thanks For The Tip. Motor Installed This Year
Baldy
Old Jul 20, 2024 | 10:37 PM
Withers's Avatar
Check the numbers on the corners of the Heads
Old Apr 18, 2026 | 09:15 PM
roninsonic's Avatar
First- What makes you think it *NEEDS* to be gone through and redone? You seem to be talking about what amounts to a basic stock freshen-up without any upgrades- why? Is something known to be wrong?
You mentioned
cam bearings, rings, main caps, gaskets and maybe crank polish.
  1. cam bearings are something you could do yourself fairly easily, and the tool is cheap to rent and fairly affordable to buy.
  2. Same with rings- If you're planning on just slapping a new set of rings in it and reusing the factory pistons, that's something you can do yourself fairly easily- you'd just need a ring pack, a ring file, and the right size dingleball hone to deglaze the cylinders.
  3. What do you mean by "main caps"?
  4. Gaskets are easy.
  5. What are you hoping to get out of a crank polish?
  6. You didn't mention rod and main bearings, line boring, checking the cylinders for straightness and/or honing, checking and potentially milling the deck surface, going over the heads and potentially doing a valve job, guides, decking the heads, swapping out the oil pump and lifters while it's apart, adding an upgraded cam/pushrods/valvesprings setup, etc.
What I'm getting at can badically be TLDR'd into 3 things:
  1. Are you sure it actually *NEEDS* to be redone?
  2. If all you're after is a bare-minimum freshen-up, you can do that yourself
  3. If you're already going to be spending the money to have a machine shop go through it and do a rebuild, now would be the time to do some upgrades- gen 4 or some forged rods, better pistons, sending the heads out to be checked, cnc-ported, and milled, upgrading to a better oil pump, getting an aftermarket cam, a set of new lifters, and an adjustable timing set and having the shop degree it in properly for you... Or, if it's all in good shape, you could use your engine as a core to buy a pre-built shortblock, and get a set of nice aftermarket heads.
Old Apr 19, 2026 | 10:40 AM
the_merv's Avatar
You mentioned -
Totally in the wrong thread guy...
