Torque converter cover 4L60 E , can’t find a fit
Have 35 Coupe with 5.3 LS and 4L60e transmission. I can’t seem to find a dust cover that fits, maybe a van tranny? Has two bid bolt holes on each side….
LS1Tech Sponsor
EASY unless it had the 168 tooth flex plate or equivalent in LS
But the 4 bolt cover only came with the smaller flexplate and can be had from a camaro , firebird, impala ss. 4.3 s10 and s15 trucks . Even the 700r4 with 4.3 and f- Bodies used it.
However if you have large flex plate you will have to modify a cover from a 6 bolt 4x4 700 or 4l60e v8 from 84 to 97
Converter dust cover
LS1Tech Sponsor
4L60e wiring
Frank, thanks for the help. I’m running LS 5.3 and I would like to use a Lokar electronic sport shifter, is it hard to wire into factory harness ? I have early Ecm with red and blue connectors.
LS1Tech Sponsor
Was wanting to use the bump stick part of it, it’s the tying into trans harness and using the micro switches to shift in manual mode that there are no instructions for. I don’t want to screw anything up LoL
I got this from the 1st part of the Lokar Electronic Sport Shifter instructions
The Lokar Electronic Sport Mode Shifter is designed and intended to be used with an aftermarket Transmission Control Unit (TCU). You will need to follow the instructions for your particular TCU in order to connect the shifter wiring. The Lokar Electronic Sport Mode Shifter may also be used with a factory Powertrain Control Module (PCM), but there are too many different combinations and too many variables for these instructions to cover those possibilities. If you are going to use the Lokar Electronic Sport Mode Shifter with a factory PCM, you will likely need aftermarket tuning software to create a custom program for the PCM, and you will need to create a custom wiring harness to connect the Shifter to your PCM.
The following users liked this post:
off2fly (09-25-2024)
