Cam position sensor issue
Old Nov 23, 2024 | 06:58 PM
39dan's Avatar
Angry Cam position sensor issue
NEW TO LS, MANY YEARS BUILDING SBC ENGINES
2003-5.3 LS Engine rebuilt and running great, revved a few times in garage and started running rough scanner said cam position sensor fault.
Replaced sensor, still runs rough and backfires upon startup. Also replaced crank sensor, no change.
UPON UNPLUGING CAM SENSOR, the engine will start fine and no backfire.
This is crazy.
IS IT POSSIBLE THAT I JUMPED A TOOTH ON TIMING CHAIN???
PLEASE HELP
Old Nov 23, 2024 | 08:35 PM
01CamaroSSTx's Avatar
Have you ruled out a bad connection on the cam sensor perhaps faulty wire?
Old Nov 24, 2024 | 08:07 AM
the_merv's Avatar
Veteran: Air Force
I'd be checking the wiring all the way to the PCM making sure its in the correct place and not damaged.
Old Nov 24, 2024 | 11:10 AM
39dan's Avatar
Default Cam position sensor
I checked pin 73 on blue connector at computer and I have nothing
I think there is supposed to be 5volts for signal
could there be an issue with the computer?
all grounds are good?
With key on and with running
Old Nov 24, 2024 | 04:55 PM
the_merv's Avatar
Veteran: Air Force
PCM Blue 73 is the Cam Sensor Signal back to the PCM.
This is the Schematic.
Old Nov 24, 2024 | 07:56 PM
jetech's Avatar
Veteran: Air Force
most people not familiar with the newer PCM/ECM controlled vehicles are very quick to blame the computer/control module. Check the sensor, the connector and wiring. Today, I fixed a vehicle the owner had the crank sensor replaced for a crank no start and P0335. The issue was a bad pin in the connector.
Old Nov 24, 2024 | 08:32 PM
the_merv's Avatar
Veteran: Air Force
Yup, I am a specialized electronics tech for my job. The stuff I've heard as a "reason" that I fix...
Old Nov 24, 2024 | 10:42 PM
39dan's Avatar
[QUOTE=the_merv;20586663]PCM Blue 73 is the Cam Sensor Signal back to the PCM.
Thanks for the info.
No signal 5v on pin 73 BLUE CONNECTOR AT ECM, GROUNDS ARE GOOD.
Possible fault in ECM???
What do you think?
Old Nov 25, 2024 | 05:43 AM
jetech's Avatar
Veteran: Air Force
You can test the cam sensor, it will generate a sine wave that can be "read" on a dvom that has a frequency setting. Here
Old Nov 25, 2024 | 07:37 AM
39dan's Avatar
Default Cam position sensor issue
I have already checked the sensor and related wiring back to the ECM
There is no 5volt reference signal coming out of the ECM on PIN 73 of the BLUE CONNECTOR
could there possibly be a PROBLEM WITH ECM??
Old Nov 25, 2024 | 09:41 AM
Are you seeing any voltage from the connector to the cam sensor with keyed on power?
Old Nov 25, 2024 | 10:07 AM
39dan's Avatar
No voltage at connector for cam position sensor signal 5v
also pulled pin 73 and checked directly to ecm … no 5v signal voltage
both with key on and engine running
DO I HAVE AN ECM FAILURE???
Old Nov 25, 2024 | 08:15 PM
jetech's Avatar
Veteran: Air Force
Not sure I'm following exactly. The 5v is coming from the sensor, not the pcm
Old Nov 25, 2024 | 08:34 PM
the_merv's Avatar
Veteran: Air Force
That's the thing there's no 5v coming from it when it's pulsing, as you mentioned below..
Guy needs to put it on an O-Scope instead of TYPING IN CAPS LIKE WE DON'T UNDERSTAND PLAIN ENGLISH, AND GO LEARN HOW THIS **** ACTUALLY WORKS.
PCM BLUE 73 is the Sensor Signal back to the PCM as a Sine Wave as mentioned above. No voltage on it you'll see with a meter.
PCM RED 39 is 5v or 12v out to the Cam Sensor. Put a meter on that and see what it is.
PCM Blue 61 is the ground of that circuit.
Again, verify ALL wiring is good all the way from the Cam Sensor Connector to the PCM. Check Pins, pull on wires a little bit to make sure they arent broken also. It's 3 wires, not hard to check.
Old Nov 26, 2024 | 03:58 PM
39dan's Avatar
Default Sorry No Disrespect
I am old and just type that way!!!!
I will try to do better next time 😎
Old Nov 26, 2024 | 05:02 PM
jetech's Avatar
Veteran: Air Force
Right Merv, I should not have said"5V coming from the sensor" I should have said the sine wave comes from the sensor. The crank and cam sensor send a sine wave to the pcm NOT 5v. The PCM can read the amount of time in between the rise and fall in the signal to determine timing events and tell when there is a miss occurring.
39Dan, you said' "Replaced sensor, still runs rough and backfires upon startup. Also replaced crank sensor, no change.
UPON UNPLUGING CAM SENSOR, the engine will start fine and no backfire. So I have to ask. Is the cam position sensor still behind the intake manifold or did you do a conversion that mounts on to the timing cover ? like this
Old Nov 26, 2024 | 07:38 PM
39dan's Avatar
Default Cam sensor location
I have cam sensor in original position on rear of motor behind intake manifold
Old Nov 26, 2024 | 07:48 PM
the_merv's Avatar
Veteran: Air Force
Well you say new Cam Sensor, what brand? I stick with the factory GM stuff.
Old Nov 27, 2024 | 08:11 AM
39dan's Avatar
All factory GM sensors but all now made in China from the dealership
Old Nov 27, 2024 | 05:55 PM
the_merv's Avatar
Veteran: Air Force
I have a stash from the junkyard for that reason, and all of them have worked when new stuff from the parts store hasn't.
