2003 Cobra Motor in a LS1?
IF you build up that ford motor it would be just as "undrivable" as the 382
Turbos are even easier to live with.
umm nooo, waste of money imo, the heads are freaking huge, you would have no room, you would be way better off with the stroker, they are just as streetable as any motor unless you go big cam which is true for any size motor.
i don't see the roots blower fitting under the cowl of the f-car, seeing as we can't fit a roots blower on the much smaller LS1 motor, let alone the beast of a 4.6 DOHC
i would like to see some pics, Could be powerful, as you can tune them a little bit better than the current ls1 software
Ryan
Ryan
Just throw in a cam and a supercharger or turbo. An forget the sacraligious effort. With those two you get power, lobe, streetability and a cool hissing or whining noise. You would also probably save money depending of if you were going to do the engine yourself.
Originally Posted by msbz_ls1
so how much hp..is the Mach1 motor puttin out same as the 99+ GT's??its the same motor right they didn't change ne thing..4.6 DOHC...only difference is shaker hood?
#32
Originally Posted by 5POINT7
LT5 engine. ZR-1 motor...came with four cams and 405hp from factory.
#36
Originally Posted by Blakbird24
In fact i'm pretty sure it's in the bible.
#37
True, True!!!!
Originally Posted by lilbuddy1587
I always thought that if you put a chevy motor in a ford it would run better, not the other way around
#38
Emissions??
I know you can definitely make a 383 stroker "streetable" but, can you make it so it can state inspection emissions tests?!?! I've always wondered about this. Any thoughts or info guys? Thanks!!!
#39
A 383 is perfectly streetable. Those few more cubes aren't going to make a car unstreetable, its what else you do.
For emissions testing, depends on what your tests are.
If its just an inspection, yes, if its a sniffer, depends on your cam/cat situation.
#40
Originally Posted by hourang
what about a header swap??
A header swap is a little different. The plugs are actually on top of the motor, right next to the fuel injectors. To change headers, you have to pretty much un-bolt the motor from the car and lift it a little to fit hands and headers in there.
Try getting a header in there without raising the engine, lol.
