doors
I belive Sub Fram Connectors will help out and may cure that. Do a search on SFC and you should get a bunch of info that you are looking for. I don't have SFC on my car yet, but plan on getting them. The car will also handle a lot better with them, less squeeks and you get more lifting points to lift the car.
Once your doors have started to drop you should get them reset as soon as possible. If you leave it too long, the striker and the hinge will start to wear as well. Any decent body shop should be able to adjust the door in about 10 minutes as well.
Or, do it yourself....it ain't hard. Just loosen the bolts near the front of the door (not too much) and lift up on the door a bit at a time. It always works better if you have an assistant (Preferably a Smokin Hot Blonde
) and they (She) can hold the door while you tighten to bolts back.
Good Luck....P.S. Send pics of the Blonde....lol
Kev Da' Cop
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
Kev Da' Cop
