Temperature & The Guages
Old Jan 14, 2005 | 10:30 PM
Zymosis's Avatar
Default temperature effect on gauges
Hey the last 2 days it has gotten extrememly cold here at night, and when I have gone out to start my car, the speedometer will jump around at like 60-70 mph then everything will zero (tach included) then it will return to normal. My trip will also resets when this happens. It has happened 2 times now. Any ideas?
Old Jan 15, 2005 | 11:57 AM
Zymosis's Avatar
Anybody?
Old Jan 15, 2005 | 12:45 PM
2001NBMZ28's Avatar
Low battery voltage can cause the sweep on start up. I'd start there. There's also a TSB for the '99 cars, but it doesn't mention the gauge sweep. #99-08-49-009 Trip Odometer Resets to Zero (Exchange/Install Instrument Cluster).
Old Jan 15, 2005 | 12:52 PM
2MuchRiceMakesMeSick's Avatar
Could be voltage could be they are just loose. I would take the guages out and clean the contacts on the back.
Old Jan 15, 2005 | 01:11 PM
Humvee z28's Avatar
my camaro did the same thing. like what he said check ur battery. has the car had a hard time turning over when u try to start it? go to any shop or autozone and have them load test the car. but my vote is for the dieing battery, this is the time of the year they go out.
Old Jan 15, 2005 | 02:02 PM
Uno99's Avatar
Here in Wi its like -25 with wind chill mine is doing the same thing.
Old Jan 15, 2005 | 09:26 PM
Full-Force's Avatar
HAHAHAHAHAHA
Dude, you have a 99. Thats all I needed to know. I asked the same question a while back. I have a 99 also and mine will do it every time when its cold. The gauges will peg out out very fast and then zero out and then correct themsleves. If you will notice you odometer also resets everytime it does it.
Seems that this was a problem with 99's.
Old Jan 15, 2005 | 09:36 PM
Christos's Avatar
I've also got a '99, it does this almost every time I start the car.
Old Jan 15, 2005 | 09:39 PM
Toms 99 TA's Avatar
My '99 resets all the time when it is cold out. I did not want to spend $300 to cure it when it only messes up on startup. Tom
Old Jan 15, 2005 | 10:39 PM
Zymosis's Avatar
Haha I'm glad I'm not the only one. I guess this, piston slap, and a few other things I just have to put up with to own an LS1.
The first time I did it I was like Wow WTF.
I will try the battery idea, I checked it before winter it was fine, but maybe it was a bit weak and the winter has taken its toll on it.
Old Jan 15, 2005 | 11:24 PM
Danny2tek's Avatar
mine is a 99 also but all the problems went away when I replaced the battery.
Old Jan 17, 2005 | 03:47 AM
Zymosis's Avatar
Wierd, it was -6 outside, I started my car, and didn't do it. But I'm sure after it sits out for another 5 hrs before work it will do it.
Battery check tomorrow for sure.
Old Jan 17, 2005 | 11:59 AM
Racehead's Avatar
It won't be a battery issue IMO. For one thing when the car is running it's not running off of the battery, but rather the Alternator. It's more than likely a connector in the harness. Since the cold seems to affect it so much I'd suspect a connector outside of the interior of the car since I'm sure you have the heater on inside ?
Old Jan 17, 2005 | 04:07 PM
Christos's Avatar
Funny, when I had my dyno done, the operator saw the gauges sweep when he started the car and said, "Woah! that's awesome!!!" he thought it was some sort of mod.
Cracked me up.
Old Jan 18, 2005 | 10:20 PM
Zymosis's Avatar
Heater is on, and I just had battery checked so IMO you were right
Ahh well, Ill just deal
