New Here, have a problem.
Old Feb 7, 2005 | 09:52 PM
camdavgar's Avatar
Question New Here, have a problem.
Alright, I am new, so hi. Now for the problem. I don't know what is wrong so I didn't know where to put it. If someone wants to move it, so be it.
OK. So my car is acting funny. Sometimes when I start going, it will completely bog. Feels like it is getting no fuel or the no air. I can let off the gas, push in the clutch, let it back out and continue on my way. I need to check the fuel pressure at the rail, but I don't have the gauge and don't know if it would do any good anyway. The car doesn't do this all the time, it's kind of sporatic.
Also, when I am going partial throttle and I shift it will be all good until about a second after I am in the next gear at partial throttle. It will bog and feels like something is being cut off. It didn't use to do this when I first got it. I have changed the fuel filter and maybe I need to do it again. I don't know. Any help is appreciated.
Could it be the fuel pump acting up sometimes? I don't think it would be the filter since it doesn't do it all the time. I also don't think it would be injectors for the same reason. Heck, maybe it is my throttle cable. I really don't know. Any ideas?
Old Feb 7, 2005 | 09:58 PM
LiquidFire350's Avatar
dont worry about the filter, that will cause problems mostly at high RPMs it will kinda surge
what conditions is this happing in, hot or cold engine, only once a day week month, or no real set pattern of when it happens, what kind of gas are you using, how many miles are on it, try some injector cleaner and some carb cleaner on the tb and see what happens
Old Feb 7, 2005 | 10:07 PM
camdavgar's Avatar
I only drive the car warm, so it is always warm, and other than that, there is no pattern. I have put sea foam in the gas tank so the injectors should be clean. I use 93 Octane gas and it has 54000 miles. It doesn't feel as strong as it should either, I don't think. But then again it feels awesome after driving my 3.4L Camaro. I will try some carb cleaner in a little bit.
Old Feb 7, 2005 | 10:27 PM
have you done anything under the hood recently and unpluged anything and forgot to plug it back in, or accidentialy unpluged it
Old Feb 7, 2005 | 10:33 PM
camdavgar's Avatar
Well, I just did headers and stuff, but it was doing this before that. Everything is plugged in, I have checked everything. Thanks for the help though. It's the best I have gotten on two forums.
Old Feb 7, 2005 | 10:40 PM
being 11pm im kinda sleepy but thats all i can come up with right now
Old Feb 7, 2005 | 10:43 PM
tcarswell's Avatar
Is sea foam supposed to go in the gas tank ? And its fuel injected is carb cleaner safe ???
Old Feb 7, 2005 | 10:45 PM
it can go in the gas tank, it helps clean the injectors that way, but to best clean carbon deposits, it should be introduced at a vaccum source near the tb
and the carb cleaner cleans the gunk **** off of the tb valve
