sportline springs
sportline springs
hey,well i just got done puting my sportline springs on & wow what a drop!!! i have read where some people have complained about there rear end being out of wac,(tires sticking out more on 1 side than the other)my car looks like everything is in good shape & lined up correctly.i have also read where i should get an adjustable torque arm since i dropped the car,which 1 do you think will work best for me & how do you know when you have it adjusted correctly???my car is a m6 & the rest of the suspention is stock.thanx john
I was thinking about lowering my car a little but my friend has had to do almost full suspension cause **** started going wrong. I dont know, maybe its just his car though
Now that you're lowered (specially with sportlines) your car does not squat like it used to when launching. This puts less weight transfer on the rear and provides less traction and a higher tendency for wheel hop. I'd say do some LCAs with relocation brackets first, and if that doesn't help you plant the rear better, then go with the tq arm. Subframes will help as well, I always recommend that being the first suspension mod.
Originally Posted by luvmeZ28
my buddy has sportlines onj his car, stock suspension otherwise, and his car rides like crap. its one of the bumpiest most uncomfortable rides ive ever had.
Originally Posted by txhorns281
lol... sounds about right. The springs will lower even further too once settled in some. Every spring needs a good shock to accompany the spring rate so if you're still on stockers better get ready to ride it cowboy! Hopefully the roads around you are pretty decent too, otherwise you could find yourself grinding all around town!
