backfire
Old Apr 28, 2005 | 10:17 PM
99FormulaM6's Avatar
Default backfire
so i searched, found nothing related. looked in other forums, couldnt pick which one it should go in...so here it is.
only at 4500 and above at WOT, backfire/slight miss(maybe). when it happens i can def feel it through the car. but the car still pulls hard, just loud popping is occuring. im going to try and resest the pcm tomorrow, and check the grounds. any other suggestions?
Old Apr 28, 2005 | 10:20 PM
Swang's Avatar
From: Hometown:Mount Carmel, IL Current: Las Vegas, NV
my friend with a 95 LT1 is having this prob too, if anyone figures it out, please respond, ASAP
Old Apr 29, 2005 | 04:10 AM
jaberwaki's Avatar
at first look it sounds like detonation, get a run logged on autotap (or equivilant) and ensure you are not picking up knock. often times a tune that is ok for daily driving can bee too lean at wot, or have too much timing advance...
if you get more details on what your hearing keep us informed
Old Apr 29, 2005 | 04:59 AM
but the only thing is that it been fine for months now.
Old Apr 29, 2005 | 05:09 AM
jaberwaki's Avatar
is there anything you changed recently?
other then that i would start some basic maitnance...
take off your maf, clean it with some isopropenal.
check your plugs and wires.
and logging a run would still be useful in trouble shooting this
Old Apr 29, 2005 | 05:22 AM
the only person i know who can log it for me is nick (suprslo), and hes in salisbury...while im in va beach. but i first noticed it when i got it back from the body shop last friday....but then it stopped...nd now its doing it again. and last night, i was seeing when it does it, and its in any gear, above 4500rpms at WOT.
Old Apr 29, 2005 | 05:58 AM
jaberwaki's Avatar
VABEACH!!!! you kiden me?....
go to
www.easternfbody.com
ask in the lounge, i'm sure someone will log it for ya...
Old Apr 29, 2005 | 08:39 AM
slow96z's Avatar
In my 96 it was a coil and valve springs
Old Apr 29, 2005 | 09:02 AM
ya, im @ efa as well. (red96ta). ill ask in the lounge and see.
Old Apr 29, 2005 | 03:28 PM
DVCrazyCamTAWs6's Avatar
could be the Opti-Spark, or bent pushrod as for as LT1's Go
Old Apr 29, 2005 | 11:02 PM
psykoTA's Avatar
Bad gas, water in the tank?
Old Apr 29, 2005 | 11:07 PM
dnkynrbk's Avatar
Hey my car did that too and got worse every time at high rpms and when it shifted into a gear fast. Only did it when I took the car at high rpms. So took it to a pro auto and said the plugs in the LS1 MOTORS where recalled and that they need to install a hotter plug and re gap to a new gap measurment. He showed me this on the internet that mech. have access to I change mine and it runs like a dream again. let me know hope this helps
Old Apr 30, 2005 | 04:52 AM
jaberwaki's Avatar
never heard of this, but then i dont know anyone running stock plugs....(be a fool thing to pay that much for plugs...)
ngk tr-55 is the plug you use for n/a
ngk tr-6 for N2O....
i still dont know why anyone would run ANY other plug....
Old Apr 30, 2005 | 06:55 AM
im gonna try and reset the computer today, and see if it fixes it. the only thing is that it doesnt do it all the time. but well see. ill see what i come up with.
Old Apr 30, 2005 | 06:10 PM
psykoTA's Avatar
Ive got stock plugs in my TA with 72K on her. Never had the issue described.
