X and Y pipe
Old May 25, 2005 | 11:32 PM
camarodude88's Avatar
Default X and Y pipe
ok i was just wondering what the difernce is between the kooks Y pipe and the kooks X pipe perfomance and sound wise
Thanx
Old May 25, 2005 | 11:39 PM
StealthZ06's Avatar
F-bodys don't come with true dual exhaust from the factory and if you are just getting exhaust, you would get the Y-pipe. If you are going all out and converting it to a true dual set up, you would need the X-Pipe.
Old May 25, 2005 | 11:50 PM
anthonyz281999's Avatar
i saw someone post this on the site not to long ago
"Now let’s discuss the two main designs for mid pipes, H and X type. An H pipe gets its name because there is a piece of pipe that connects each side of the pipe that connects to the header collectors (hence the name H pipe). This pipe is supposed to help equalize the pressure and thereby create a better scavenging effect. An X pipe however, has each side of the pipe meet in an X type junction. Again the idea is to equalize pressure and create better scavenging. As a general rule, H pipes allow for more low-end torque and slightly less Horse Power than X pipes do. Also, the sound note is quite different. The X pipe has a raspy sound while the H pipe is more “muscle car” sounding. As mentioned, the mid-pipe choice seems to be a personal sound preference and most people who use chambered mufflers opt for the H pipe, while the straight through users tend to choose the X pipe. Typically, the X pipe/straight through muffler combination yields higher HP and lower torque than the H pipe/chambered muffler design."
