My First Problem!!!
Old May 30, 2005 | 07:38 PM
chocolatemilk's Avatar
Default My First Problem!!!
Hey guys new to this site. but i have a 2000 z28 with about 38,000 mile on it that i bought last febuary. well anyways all of sudden i go to start my car this morning and it wouldn't idle rite. it would go to 400 ..seem like its about to die and then jump to 600. It did throw a code at me last week for a bad o2 .. i had the code deleted but i was told that if the ses light came on i should get it changed . only reason i havent gotten changed is becuase money.any help would be awesome cuz this thing is really stressing me out. Thanks
...ps sorry if this a bit confusing im at work and just stressed.
Old May 30, 2005 | 07:46 PM
glennhl's Avatar
When my car had erratic idling problems in the past, I've always fixed by cleaning out the Inlet Air Control Valve. It's on the side of the throttle body. Take it off and clean it with carb cleaner.
Old May 30, 2005 | 10:25 PM
Swang's Avatar
From: Hometown:Mount Carmel, IL Current: Las Vegas, NV
yeah, fuel pumps do that sometimes but i wouldnt see a fuel pump goin at 38k. what the guys above said.
Old May 30, 2005 | 10:50 PM
Bow94z's Avatar
IAC? fuel pump?
Old May 31, 2005 | 04:28 AM
jaberwaki's Avatar
replace the O2 ...
if your DELETED it , it will not comeback...but you will still have a bad O2...
if that does not fix it(but i think it will)
then i would look at cleaing your IAC.... not the IACV....
IAC=idle air controler...
Old May 31, 2005 | 11:04 AM
glennhl's Avatar
Originally Posted by jaberwaki
replace the O2 ...
Thanks for the correction. Idle Air Controller, not Inlet Air Control. However, it still is a valve.
Old May 31, 2005 | 11:28 AM
'Trust''s Avatar
Do you know what code it was or what it said? bank 1 or bank 2, ring any bells? if it was your rear O2's then its ok to delete them, but your fronts is a no no, i say go cheapest first, clean your IAC valve, if that doesnt work, fuel filter, then if that doesnt work replace the O2 sensor, those things are like 110 bucks from GM, but im sure you can find some on ebay for cheaper, or if you know someone w/hp tuners have them delete your rear o2's and replace them with the ones up front, they are interchangeable, although i dont know if the wireing is long enough,
Old Jun 1, 2005 | 04:13 AM
jaberwaki's Avatar
they are 79 bucks from advanced auto
 Michael S. Palmer
