Request Part Numbers
Old 08-16-2006, 11:40 AM
  #361
MM98's Avatar
Originally Posted by Ferocity02
Interior light dimming ****(potentiometer) for 99 Z28.
There's two different styles:
-Part#10287202, with rpo code# wx7 (wrg provisions), which you probably do not have, but just incase.
-Part#12450124 (without it).
Old 08-29-2006, 10:25 PM
  #362
MadMike329's Avatar
here's one for you that i couldn't find. the little bulb inside the glove box.
Old 09-01-2006, 10:01 PM
  #363
Mentu13's Avatar
I need the part number for the two rubber flaps for the SS hood that better direct the air into the bottom of the lid, from the ram air output of the SS camaro hood. 1999-2002.
Old 09-02-2006, 12:19 AM
  #364
ACW
ACW's Avatar
glove box lamp (12V 2CP lightbulb) (97-02) (AC-Delco #L194) = 9421330
Old 09-02-2006, 01:06 AM
  #365
ACW
ACW's Avatar
Originally Posted by 30thz
found it
RH 22146933
LH 22146934
Thought I should point out that those appear to be backwards.
Everything I'm seeing says:
front strut/shock upper mount (93-02), LH = 22146933
front strut/shock upper mount (93-02), RH = 22146934
Old 09-02-2006, 01:44 AM
  #366
Wnts2Go10O's Avatar
LS1 starter?
Old 09-03-2006, 06:55 PM
  #367
Shallow Bay's Avatar
Anybody know the part number for the clip in the picture below? Thanks!
Old 09-03-2006, 11:50 PM
  #368
Ferocity02's Avatar
01-02 Clutch Master Cylinder
Black plastic radiator air dam
Driver's side splash gaurd, the black plastic box looking piece with little vents, in front of the wheel
Old 09-04-2006, 02:39 PM
  #369
Wnts2Go10O's Avatar
hawks third gen has the air dams for 3rd and 4th gens
Old 09-04-2006, 10:47 PM
  #370
ss2668's Avatar
Hey i cant find the part # for the idler pulley for the main belt. The Tensioner for the mainbelt is 12560344. The AC belt tensioner is 12560345 and ac belt idler pulley is 12557335
Old 09-06-2006, 01:36 AM
  #371
Part No. 12564401
Old 09-07-2006, 10:22 AM
  #372
Joel_SS's Avatar
caliper frame bolts Parts #
Does anyone have a part number? Mine fell out yestarday while driving! Just to clarify it the the 15mm bolt that is torqued to like 74 ft lbs
Old 09-07-2006, 11:53 AM
  #373
tmgsix's Avatar
Part # for the front wheel hub assembly would be greatly appreciated!!
Old 09-07-2006, 02:09 PM
  #374
Part No. 18023646
Old 09-07-2006, 03:02 PM
  #375
Joel_SS's Avatar
Originally Posted by Shallow Bay
Part No. 18023646
Thanks!!
Old 09-14-2006, 09:52 AM
  #376
Bad Mojo's Avatar
Search doesn't seem to be working for me (just goes to a blank white page) so I hope this hasn't been asked already... I'm looking for the part # for the driver's side a-pillar trim cover, I think it's called "garnish trim" in the manual. For a T-Top 4th gen, with Ebony interior.
Thanks!
Old 09-14-2006, 11:42 AM
  #377
LS1GMCTruck's Avatar
Default 1996 GMC C-1500 Pick-Up
On the A/C Dryer Cannister on the firewall, there is a black rubber cover that covers the whole cannister from the factory. Would it be hard to get me the part # for that black rubber cover? Thanks very much, Gar
Old 09-14-2006, 01:11 PM
  #378
Ferocity02's Avatar
Fix this part number: LS1 camshaft position sensor (with seal) (99-02) (AC-Delco #213-363) = 12561311
Should be 12561211
Old 09-15-2006, 11:48 AM
  #379
black99z28's Avatar
I looked, but maybe i missed it, i need the # for the light that goes in the piece that goes behind the door handle and has the lock, its like an accent light.
Old 09-19-2006, 12:14 PM
  #380
Part No. 9437979
Quick Reply: Request Part Numbers
