Request Part Numbers
#381
Originally Posted by Bad Mojo
Search doesn't seem to be working for me (just goes to a blank white page) so I hope this hasn't been asked already... I'm looking for the part # for the driver's side a-pillar trim cover, I think it's called "garnish trim" in the manual. For a T-Top 4th gen, with Ebony interior.
Thanks!
Thanks!
#382
Originally Posted by LS1GMCTruck
On the A/C Dryer Cannister on the firewall, there is a black rubber cover that covers the whole cannister from the factory. Would it be hard to get me the part # for that black rubber cover? Thanks very much, Gar
#389
Looking for a few block parts. I have a new block. I need lifter tray hold down bolts, front press in oil plug next to oil pump, rear "bar-bell" oil restrictor plug, drivers side rear screw in oil plug, cam shaft retaing plate and bolts, cylinger head locating dowles, tranny locating dowles...
#396
Could I get the part numbers for:
LS7 ignition coils
6.0L truck ignition coils
Ls1 lifter tray
Driver side vehicle speed sensor (I think that's what it is) the wires that clip in by the brakes that can get accidentally caught and ripped off when removing an engine from the bottom
Thank you!
LS7 ignition coils
Ls1 lifter tray
Thank you!
#397
Need the following:
-Throttle Position Sensor (f-body, different part #s for different years?)
-Crankshaft Position Sensor seal
-Camshaft Position Sensor seal
-Oil pressure sending unit/sensor (f-body, different part #s for different years?)
-Oil Level Sensor with seal (f-body)
-LS2 flywheel bolts (C6)
-LS2 clutch pressure plate bolts (C6)
-"LS6 intake manifold seal = 12560251" - please clarify what this is/where it goes
Thanks, Brad
Thanks, Brad
