Request Part Numbers
Old 11-04-2006, 06:01 PM
  #401
giant016's Avatar
If I could get the # for the shock sensor in a 2000 SS I would appreciate it!
Old 11-05-2006, 05:19 PM
  #402
kny3twalker's Avatar
I own a 99 Formula Firebird, white exterior, grey Cloth interior (medium grey I would guess)
I need several part numbers
Exterior:
1 Firebird (non T/A) front bumper cover
2 Passenger Side Headlight bracket, I do not need painted panel, motor, bezel for lights, etc... if possible
3 The plastic part which you open underneath the car to replace the turn signal bulbs
4 Both Front Bumper Turn Signals/Daytime Running Lights
5 The Wind guard beneath the Front Bumper
6 Driver's Side Drip Molding
Interior
1 Sun Visors (Both)
2 Door Panels (Both)
3 All parts related to the driver's side power window (only parts in the door)
my window just seems impossible to be fixed, it constantly breaks
4 Shifter Boot for Six Speed Manual (do not need clip, bought custom made one on here)
5 carpet (dark grey)
6 trunk/hatch carpet (very dark grey/Black)
7 Turn signal lever (with cruise control and window wiper control)
8 Both Front Floor Mats (dark grey)
9 Back Seat Seatbelt Bolt(lower)
10 Driver's Side Seat Cushion and left side lumbar support, or seat back if thats how they are sold
(seat is power but non-adjustable lumbar)
11 The retainers clips/pins for both rear hatch panels(I know they are different)
the Driver's side are white clips which pin in and can only be seen from under the panel where are passenger side are turnable clips which allow easy access to spare tire
I have been able to locate some of the part numbers but I am sure if they are correct
any help would be appreciated
Thanks
Robert
Old 11-07-2006, 10:06 PM
  #403
kidfrostbite's Avatar
I need the part number for the rear hatch lock actuator/motor/solenoid or whatever it's called.
Old 11-13-2006, 06:42 PM
  #404
1baddls1's Avatar
part number for pass (right) front caliper bracket (that the guide pins slide into) since one of my guide pins is completley ceased - or does this come with the caliper???
Old 11-14-2006, 09:46 AM
  #405
RacerScott's Avatar
Can i get the part number for a 1998 camaro headlight bulb, Low and high, and the part number for the fog light bulbs, 894 I beleive they are. Thanks Scott
Old 11-24-2006, 05:05 PM
  #406
96silverram's Avatar
1996 WS6 T/A (Firebird) guage bezel part #
Please,
Old 11-26-2006, 12:23 AM
  #407
bradl1982's Avatar
Originally Posted by MM98
Here you go man:
FRT LH & RH ebony seat back cover(leather): #16837696
FRT LH & RH ebony seat cushion cover(leather): #16837698
Rear LH & RH ebony seat cushion cover(leather): #16840531
Rear ebony seat back cover(leather): #16840538
Mike
Probably a dumb question but those part #s aren't for the set right. You have to order 2 each for the lh and rh?
Old 12-01-2006, 03:46 AM
  #408
LS1TECH Sponsor
Azar's Avatar
Alternator brackets for 98 LS1, thanks!
Old 12-01-2006, 03:06 PM
  #409
Shallow Bay's Avatar
Anybody know what happened to ACW and MM98?
Old 12-02-2006, 04:04 PM
  #410
vader99's Avatar
I need a part number for a front seatback cover:
Front LH dark grey (graphite) seat back cover (leather) for 1998 - 1999 trans am aq9 lumbar seats
thanks...
Old 12-03-2006, 12:23 PM
  #411
JasonWW's Avatar
Can anyone tell me what this GM part number fits?
15118218
It's an airbag module, but I have no idea what vehicle it's for.
Thanks
Old 12-04-2006, 09:25 PM
  #412
JasonWW's Avatar
Can someone check the 03-06 chevy PU or tahoe air bag module?
That's what it looks like.
Old 12-06-2006, 12:40 PM
  #413
blkbird's Avatar
I looked but couldnt find the alternator itself on your list. That would be appreciated. Thanks.
Old 12-06-2006, 05:43 PM
  #414
kawasakiklx's Avatar
how about the part number for the trans am side fascia retainers, should be push-pin style...
PM please.
Old 12-06-2006, 11:49 PM
  #415
ls1 1990 VN's Avatar
Want to know part #s for pre 02 Vette "Throttle position sensor" & "Idle speed control stepper motor" that operate the drive by wire TB.
Also part #s for the same parts on the cable operated TB on the F-Body.
Thanks.
Old 12-07-2006, 01:03 AM
  #416
LS1TECH Sponsor
Azar's Avatar
Goood question....
Old 12-09-2006, 09:32 AM
  #417
MM98's Avatar
Could I have the part number for the rubber plugs that close the 6 or so holes on the bottom of the car?
Part#10208798
part#16629978 (97-98')
part#16635227 (99-02')
part#18026163
part#1999366(low)
Part#9441732(high)
part#12450260(fog)
part#17997874
That's correct.
part#12563327(big one)
part#12556915(small one rear)
part#16795307
15118218
03-07' pickup or g-van.
part#10464407
part#26099808
part#17113669( throttle body assm with actuator, vette)
part#17113566( tps, vette)
part#17113391(IAC motor, f-car)
part#17123852(tps, f-car)
-Mike
Old 12-09-2006, 10:33 AM
  #418
MM98's Avatar
Daytime Running Light bulb?
part#1999366
I'm looking for the part# for the sun visor mounting post.
part of sunvisor
Plastic guage cover that covers the instrument panel. I know it seperates from the cluster and was looking for the part number for just the plastic cover....thanks!
part#10410608
2002 Trans AM w/Monsoon system, coupe.
There are 2 sets of speakers in the rear hatch area.
I'm looking for the part numbers for these speakers.
part#16259011(big)
part#16229091(small)
could i get the part number for a 1998-2002 TRANS AM bumper cover? NOT the formula style but the actual TRANS AM one?
part#10418941(frt)
part#12335511(rr)
What is the part number for the valve cover bolts for 99 and up heads? There's four of them per head, I broke one and need to replace it. Thank you.
part#12577215
Part number for the upper dash pad on the 97 trans am/camaros, if possible for each color so i'm sure to get the right one.
part#10422746
Could I get the part numbers for:
LS7 ignition coils
6.0L truck ignition coils
Ls1 lifter tray
Driver side vehicle speed sensor (I think that's what it is) the wires that clip in by the brakes that can get accidentally caught and ripped off when removing an engine from the bottom
part#12573190(ls7, round style)
part#12570616(ls7, square style)
part#10457730(6.0, delphi)
part#12558693(6.0, mitsubishi)
part#12551162(lifter tray)
part#7470587( f-car hub assm with speed sensor)
Need the following:
-Throttle Position Sensor (f-body, different part #s for different years?)
-Crankshaft Position Sensor seal
-Camshaft Position Sensor seal
-Oil pressure sending unit/sensor (f-body, different part #s for different years?)
-Oil Level Sensor with seal (f-body)
-LS2 flywheel bolts (C6)
-LS2 clutch pressure plate bolts (C6)
-"LS6 intake manifold seal = 12560251" - please clarify what this is/where it goes
part#17123852(tps 98-02)
part#12560228( crank sensor seal is serviced only with new sensor)
part#12561211(cam sensor seal is serviced only with new sensor 99-02)
part#12562267(oil pressure sensor 99-02)
part#12603782(oil level sensor)
part#12553332(ls2 flywheel bolts)
part#12561465(ls2 pressure plate bolts)
part#12560251, I think is the foam seal on the bootm of the intake.
Could I get the part numbers for the factory 1:7 roller rocker arms
part#10214664
Sorry it's taken so long fellas, I started different hours at my job & it takes up alot more of my free time.. I'll crank out part#'s for you guys as fast as I can.
-Mike
Old 12-09-2006, 10:51 AM
  #419
JasonWW's Avatar
It's appreciated, thanks.
Old 12-09-2006, 04:36 PM
  #420
vader99's Avatar
thanks alot....you're a great help!
Quick Reply: Request Part Numbers
