Request Part Numbers
Old 12-10-2006, 10:37 PM
  #421
ls1 1990 VN's Avatar
Thanks for that, very much appreciated.
wayne
Old 12-21-2006, 10:45 PM
  #422
plusandrew's Avatar
plastic thing over it was cracked and it broke off.
need to know what it is and what the part # is if possible.
or..
the part # for a tan seat belt for 98-02
Old 12-22-2006, 09:35 AM
  #423
staringback05's Avatar
i need the altenator part number for a 01 TA....its not on the parts list...only bolt part #s
Old 12-22-2006, 10:06 AM
  #424
TRANSAM75's Avatar
10464407 List$325.34
Old 12-22-2006, 10:15 AM
  #425
SOB.....i should have took the hint when the GM guy told me "wholesale" it was 270.....
Old 12-23-2006, 04:24 PM
  #426
spike30th's Avatar
You got the part number for 97 camaro fog light socket? thanks
Old 12-24-2006, 02:53 PM
  #427
sfevera's Avatar
sorry first time vehicle is 99 camaro 3.8 am looking for the bracket that holds the ac compressor problem is that mine broke and needs a replacement could someone please give the number for the part and where i might be able to purchase it thanks
Old 12-26-2006, 06:42 PM
  #428
MM98's Avatar
part#88896026
part#12102664
part#24506755 (frt bracket)
part#24504706 (rear bracket)... You can get them at the dealer or a salvage yard.
-Mike
Old 12-26-2006, 09:09 PM
  #429
LS1MONSTER's Avatar
I searched but was unable to find the part# for stock exhaust manifold gaskets on a 98 Z28. Any help is greatly appreciated!
Edit, i found it. 12558573
Old 12-27-2006, 06:41 PM
  #430
mike s.'s Avatar
Need power steering cooler lines for this cooler LS1 power steering cooler (98-02 with RPO V12) = 10417037, imnot sure if this is one of the two LS1 power steering inlet hose (98-02) (AC-Delco #36P13056) = 26075068
Old 12-28-2006, 01:48 AM
  #431
buglight56's Avatar
Hi there I was wandering if you could possibly tell me the part numbers for the seats in my 96 trans am I am really needing the drivers seat covers but if you have all the numbers that would be even better thanks in advance the rpo codes for my car are
12I - INTERIOR TRIM, GRAPHITE (92)
122 - TRIM COMBINATION, LEATHER, GRAPHITE (2) (92)
if this helps thanks again
Old 01-01-2007, 02:10 AM
  #432
vader99's Avatar
Hi Wayne.......
Could you give me the part number for the plastic cover that goes on the backside of the driver side leather seat of my 1999 trans am with the AQ9 lumbar seat option. It has to be the dark grey color for 1999.
thanks....
Old 01-06-2007, 07:20 PM
  #433
Dope's Avatar
I've been searching around, but I can't find correct part #s for these 3 things:
Front driverside seatbelt assembly for a 98 Camaro SS (gray cloth interior).
Both belts for the same car. I have some part #s but gmpartsdirect tells me one of them is no longer valid. They are: 12561860 and 12559327
Thanks so much.
Dope
Old 01-10-2007, 12:39 PM
  #434
Dope's Avatar
Dope
Old 01-23-2007, 12:00 PM
  #435
Juiced's Avatar
I need an 93 LT1 transam Body harness
Old 01-26-2007, 03:57 PM
  #436
wvaboy's Avatar
i need a drivers side a pillar part number for a 99 t/a with t tops.
is it part #part 10408110?
any idea how much i should expect?
thanks,
rob
Old 02-02-2007, 12:47 AM
  #437
00CaliforniaZ28's Avatar
Hi. I needed the part number for the entire dash assembly for a 2000 camaro if you have it. Im looking for the large part where the radio bezel and ac vents and everything attach to. Thanks for any help!
Old 02-04-2007, 08:29 PM
  #438
richdalenta's Avatar
Looking for part numbers for 2000 firebird formula:
headlamp "buckets" (what the lamps fit into) & retaining rings
Also export versions of above buckets (they would have a round hole in back rather than square). Thanks.
Old 02-06-2007, 12:29 PM
  #439
MrEddie's Avatar
I didn't see this part in the list, but I may not know what it's named. Anyway, it's the plastic baffle that fits on top of the AC condenser (piece that is cut during the free ram air mod). Oh, it's for a 2000 Z28. Thanks!
Nevermind - I checked the helms and the part numbers were listed here:
25170361
10409095
Old 02-06-2007, 10:17 PM
  #440
GIGAPUNK's Avatar
LS7 Clutch disc only (no pressure plate).
Some people have told me that you have to buy the new pressure plate/clutch disc package. But that doesn't make any sense to me.
Quick Reply: Request Part Numbers
