Request Part Numbers
#545
i need the part number for a 2002 LS1 power steering rack&pinion. ive gotten so many different part numbers and my very own 02 Z28 has a part number of 26048277 which is different from the part number posted on that list of 26062311? also i tried entering my part number on GM parts direct and i got nothing? what is up?
#546
I need the part number for the plastic piece that goes around the handle and lock on the driver's side. It also holds the piece with the power window, mirror, and lock controls. Not sure what to call it exactly. It's for a 2000 Z28. Any help would be appreciated, thanks.
#547
LS1/LS6 coolant pipe (01-02) (need for installing LS6 intake manifold) = 12568478
LS1/LS6 coolant plug (01-02) (need 2) (need for installing LS6 intake manifold) = 12562788
#548
Does a part number exist for the bushing in the clutch master cylinder rod??? I dont know if something separate like that is available. Im doing something somewhat custom, so if anyone knows, let me know!
J.
J.
#550
From: Heidelberg Germany (1.4 miles from famous Hockenheim Ring)
I want to make sure, that THIS: window outer sealing strip (93-02), RH = 10284222 is the weather strip thats out side of the window, keeps popping off, and i broke a few of the clips trying to fix it, and unless any one here has tips to install it, i'll have a garage install it.
Also, i need a clip for the window/door lock switch holder thing for it to clip to the door panel, will i just have to buy a new switch thing?
#552
LS1/LS6 coolant pipe (01-02) (need for installing LS6 intake manifold) = 12568478 replaced by 12602544
LS1/LS6 coolant plug (01-02) (need 2) (need for installing LS6 intake manifold) = 12562788 replaced by 12602540
#553
26062311 is the part for your car. When you say "your" number, if that is the number stamped or molded into the part? If so, ignore it, that is a production part number and has been changed and superceded a long time ago.
#554
#555
#556
It gets even more confusing looking at the specs. The t-stat in that part numbered housing is designed to start opening at 186.5*f and full open at 212*f.
Ive done multiple searches and came up with 12571261 which is for 98-02 ls1's but its a 195*. Owner's manual for 01-02s says the 5.7 has a 180. I cant comfirm this. Trying to decide to go with 160 or not. If it does in fact have the 180 than i can get the money back for my slp 160 stat.
#557
Need Part Numbers For Firebird AQ9 Seats
For 2002 Firebird TA Ebony Leather Interior AQ9 (adj lumbar & side) seats
1. Plastic seatbacks (back cover, solid unpainted plastic, LH & RH - the part that have the nets)
2. LH drivers side seat bottom control panel (1 6-way switch, 2 rockers)
3. RH passengers side seat bottom control panel (2 rockers)
Note: do # 2 & 3 come in the correct color (ebony) or do you have to paint them? Thanks.
#558
so is that actuall part number any where at all on the steering rack? if so where is it located i just want to check a few racks out and make sure i got the right one...
#559
If there is a number on the rack it can be pretty hard to cross reference back. Some times its a good number, other times it not. Once a part starts changing service part numbers it can get pretty confusing.
#560
I need to know what these came off of, as far as year, trim level, ss.
Delphi-made in USA 01100912 22199128 M48, it's a front, and have a yellow tag on the spring, all I can make out is that it says ABS, and the 2 second to the last numbers are 22
deCarbon- made in France FRONT 3300 0 BN, also front, has yellow tag on spring 22077190
rear spring- all I can make out is **077420
Thank you very much ahead of time.
James
James
