Request Part Numbers
#561
None of the parts show anything specific for the SS. You would need to match the two letter codes to see if they are the same as your vehicle.
The hardest part is, over time the codes in the system get superceded and will not match what the older car may have on it.
22199128 - front shock absorber, 1993-2002 F car all models
22077190 - originally a 1994 part code FYJ, replaced several times after that with new numbers
22077420 - 1995 rear spring - newest part number will service 1982-2002, nothing special shown for usage.
#564
I looked and looked but couldn't find it...
I need the part number for the wiring connector that connects to the electric window motors. Somehow the one on my drivers side window motor in my `99 SS is cracked and loose, causing my window to die intermittently.
#570
Are the plastic "covers" that cover the bolt that holds the windshield wiper on a part of the entire windshield wiper assembly or can they be purchased separately? If they can be purchased separately, what's the P/N?
Thanks,
Adam
Thanks,
Adam
#573
#576
Double check the RPO label, your trim code should be 52I, light neutral. They only list neutral and ebody.
10326252 right side
10326253 left side
In the future, if you do not know the codes or other info, your VIN will be needed, there are too many different options and combinations involved in looking up parts.
10326252 right side
10326253 left side
#577
So which is it? Different generations of cars. If you want to get the right answer get more information. If you walk into a dealer or any parts department with that request they will just laugh and blow you off. Not trying to be a jerk but I like to help you guys out but when you need a part you have to provide some level of detail to get the right part.
#579
