Request Part Numbers
#641
Both fit well in a 69 Camaro.
I need part numbers for all the bolts on the Corvette Accessory drive.
bolts that mount it to the block and head and bolts from accessories to bracket.
#643
Anyone have a definite list for the 98- up FBody LS1 accessory drive? I found a partial list in the hybrids "sticky" but I need everything less AC brackets. This includes the pulleys and so forth.
Thanks!
Thanks!
#646
Go to a dealer tell them what you are doing and have them pull up the pictures and parts for a 2002 F car. Most parts guys are good about it.
#648
Part number for Headlamp door??
Need help.
I need the part number for a 98-02 firebird headlight cover/door/lid for a project I'm doing.
#653
Does anyone have the part # for 02 Firebird Fuel door as well as the weatherstripping on the T-Top to window connection?
Someone was nice enough to clip my fuel door but I guess I should be happy they didn't completely side swipe me :shrug:
Thanks
Thanks
#655
need part numbers
Anyone have the part numbers for the plastic shields that bolt to each lower rear side of the LS1 block?
These are the plastic shields that cover the flexplate opening to the transmission on the LS1 engines. On gen 1 & II engines this would have been the flywheel cover.
On the Gen III engines these are mounted on each side, with the larger one being on the passenger side I think.
Thanks!
Thanks!
#659
Needing to confirm differences between these threaded ball studs for the prop rods on the rear hatch. It is listed as part # 37 in the link below
LINK
There are (2) 37's listed. I would guess that one is threaded and one is not. Not sure of the difference.
Also want to confirm my thoughts on the passenger rear panel that the fasteners are correct. I have the quarter turn retainers in there and want confirm PN 16673676 from
LINK
LINK
LINK
