Request Part Numbers
Old Jul 18, 2017 | 04:55 PM
  #761
garyl's Avatar
Default how do I figure out what Ls model I have?
the block is stamped 12567393 the heads have WFC 706 it is a super charged engine. I am hoping someone can help.
thank you
Gary
Old Jul 19, 2017 | 01:54 PM
  #762
LS6427's Avatar
1998 WS6 Trans Am
4L60E
Complete engine/pcm/sensors wiring harness....?
Thanks.
Old Oct 28, 2017 | 04:17 PM
  #763
Kcutty85's Avatar
Ls1 brake booster to back of intake manifold vacuum hose ?
Old Mar 22, 2018 | 11:39 AM
  #764
Monte87SS's Avatar
Default Ebony seat belts for 98 model year
Need all 4 seats (belts and buckles) parts numbers please, in ebony for 1998?
TIA!!!
Old Jan 10, 2019 | 11:59 AM
  #765
blk97z28's Avatar
Anyone know the part number for the SLP 3rd Brake light in terms of the connector. I have 2 Hawks Motorsports SLP new lights, but no connector.
I want the factory look, so the lights have the ends stripped, I just need a connector I can run those bare ends into and install.
Old Jan 10, 2019 | 12:00 PM
  #766
blk97z28's Avatar
TIA!!!
ebony was 00-02
Dark Gray or Very Dark Gray was 97/98/99
Charcoal was 93-96
Old Jan 29, 2019 | 04:13 PM
  #767
sjsingle1's Avatar
the U clip that goes on the front top of the fender 98-02 birds....takes a 4 mm bolt/screw thru the bumper bracket ....if you look behind the headlights you can see it
dealer cannot find it anywhere in the computer
it measures 20.3 x 13.6 from the back side
Old Feb 2, 2019 | 11:13 PM
  #768
sjsingle1's Avatar
I still do not know the GM p/n of the clip but I got a bag of Hillman speed nuts at Lowes...#8....not exact but pretty good fit
Old Apr 2, 2019 | 03:49 AM
  #769
kookamunga's Avatar
looking fo rthe part number for the apron the protects the drivers side of the rack and pinion and alternator. mines torn and I cant find it anywhere
Old Apr 2, 2019 | 05:55 PM
  #770
sjsingle1's Avatar
I believe it is NA....if you have whats left of your old one you could make one
Old Sep 22, 2019 | 04:48 PM
  #771
Z28Roxy's Avatar
Looking for the part numbers for rear bumper and rear fog lights for an export camaro (think it's all the same whether it's for a 93 or an 02).
What I'm talking about:
https://farm4.static.flickr.com/3618...4d316e04_o.jpg
Don't need 5978079 and 5978080 (export tail lights) though.
EDIT: Looks like I found the rear bumper part #. It's 10277161
If anyone finds or knows the rear fogs I'd appreciate it as well!
Old Aug 4, 2020 | 03:40 PM
  #772
Z28Roxy's Avatar
I need the part number for the metal bracket that attaches the filler neck to the body.
Specifically this:
https://ls1tech.com/forums/attachmen..._173243670.jpg
Old Aug 5, 2020 | 08:08 AM
  #773
FirstYrLS1Z's Avatar
Active Streak: 30 Days
The parts layout catalog does not show that bracket. Your picture shows it is riveted on, so it's evidently a part of an assembly.
Old Nov 30, 2020 | 09:27 PM
  #774
Blksilvr's Avatar
Default Firebird Door speakers
Does anyone have the part number / size type of screw that holds the factory 1998 Trans Am door speaker to the plastic adapter for the door ? I have not found anything in the search & the local stealer ship is no help .
Thanks
Rick
Old Dec 1, 2020 | 07:55 AM
  #775
what year ???
Old Dec 1, 2020 | 09:07 AM
  #776
Blksilvr's Avatar
1998 Trans Am
Old Dec 1, 2020 | 04:49 PM
  #777
Per the layout catalog; SCREW, LG RD HD TORX TAP M4.2 x 1.41 x 20 SS BL OX (RDO FRT S/D SPKR. The number appears to be 16751144.
Old Dec 2, 2020 | 07:09 PM
  #778
Blksilvr's Avatar
Thanks .
Old Feb 26, 2021 | 01:07 PM
  #779
Michael Perez's Avatar
Default Performance Cam shafts
Hi I have a 2001 Camaro SS I am new to the ls1 platform and was looking at cams on summit racing, I was curious if any of you had any luck with their cams, and if so which one did you go with? What I'm looking for is a stage 1-2 I'm leaning towards stage 1 but would like a cam that has the most aggressive profile, but doesn't need a stall converter because I like to take the car out on the town on the weekends.
Old Jun 10, 2021 | 10:10 PM
  #780
gen_protection's Avatar
UPDATE: Disregard. A. FYI for anyone else looking for this answer, that middle line doesn't have a retainer clip like the fuel lines, it just snaps over the evap fitting and locks on the ridge of the fitting itself. B. I'm an idiot for not noting that when removing the old pump. Lesson learned.
I've been looking for this for days now. I need to find the retainer clip for the middle hose (evap line?) of the fuel pump sending unit on a 2000 Trans Am. I replaced my fuel pump and it didn't come with the clips that keep the hoses on the sending unit fittings. Old pump was gone by the time I noticed.
