help installing this?
Old Aug 4, 2005 | 08:02 PM
andypdbz's Avatar
Default help installing this?
i have the ftra install and i have the stock air lid but wiill be replacing it soon with an slp lid. so do i not use the foam seals and save them for the slp lid?
also, will i have any hassle doing this? i dont have a robertson screwdrivero, never even heard of the thing. also will i have to do a lot of cutting?
thanks
also, anyone know where i can find detailed instructions, with hi res pics?
sorry i posted this in another thread but i figured i would get more feedback w/ a new thread.
Old Aug 4, 2005 | 08:20 PM
jaberwaki's Avatar
i would hold off on the install till your lid gets there and do it all at once.
the only cutting that i know you will have to do is the FRA mod. the FTRA fits right in the same hole....
do a search on FRA mod and it should turn up pics...
and this is what the skrew driver looks like....
http://www.cabinetmart.com/03-rob.html
Old Aug 4, 2005 | 09:59 PM
andypdbz's Avatar
but if i do install it and replace the stock lid with the slp one, i dont have to do anything or modify the ftra right?
Old Aug 4, 2005 | 11:54 PM
felton316's Avatar
Correct
What did you need a robertson screwdriver for? I've installed FTRA's and never needed one.
Also, the foam goes on the underside of the lower airbox and not the lid. You should be able to install 1000's of lids and never have to touch the foam.
pic off of Fast Toy's website
It seals the metal ram air kit to the plastic lower air box.
Old Aug 5, 2005 | 12:22 AM
andypdbz's Avatar
awesome, this answers my question perfectly, thanks for the help
oh and there were some screws that need that screwdriver but im just gonna use regular screws instead....
Old Aug 5, 2005 | 04:13 PM
andypdbz's Avatar
ok so im installing this and the air box base wont clear the radiator, it has those spaces to put on the radiator itself but it seems the radiator was pushed back. did i move something out of the way?
i forced this in and its tough to close the air lid and the bellow keeps coming loose at the throttle body.
i managed to put this in tightly but theres like a whistling noise now, you can only hear it when the hood is open and i cant make out where its coming from.
help please
Old Aug 5, 2005 | 08:26 PM
andypdbz's Avatar
any help?
Old Aug 5, 2005 | 09:21 PM
jaberwaki's Avatar
it sounds like you either moved yourself, or it moved by itself from its seat... try picking the radiator up and reseating it...
other then that i really cant picture what is wronge without seeing the car...
no i am not flying to el paso
Old Aug 5, 2005 | 09:34 PM
'Trust''s Avatar
help please
Alot of times you need to pull the radiator towards the front of the car and slide the lower air box piece ontop of it so it holds it like its suppose to, the whistling noise is because you had to cut that plastic, it slienced the air, now it cant, dont worry about it
Old Aug 5, 2005 | 11:44 PM
andypdbz's Avatar
thanks man, appreciate the advice
