Ready to get started.... what to do first?
What about intakes... are the volants worth it, or will they be pretty simular to the slp industion kit? sorry if these are repeat questions. i just bouth the car and am ready to modd it. i already bouth the skip shift eleminator the second day i had the car. lol. and does anyone know where i can get a good set of chrome vette rims? the thin 5 spokes in 17's or 18's.... thanx alot.Will
-Mike
As for intakes a lid is a lid is a lid, not much difference in hp gains, so get one used or on sale (I got the SLP)
Wheels, look at the banner for TomZ wheels--------------------->
And get a set of SFCs (should be one of the first mods you do makes the car alot tighter feeling)
without a ram air hood though, you're probably better off with a lid and ftra or something similar..
sub frame connectors are a brace that goes under the car in the rear, it stiffens the whole car's rear suspension, making it handle better under power.
car will launch better, and most will say it removes alot of rattles and such you hear on stock vehicles.
You can get cheap ones for as low as 100 bucks I think, but do yourself a favor and do it right, get a pair of KB DD's or the umi 3 points, which they run 200 and up.
You won't lose anything.
You gain a stiffer car, and a few pounds in weight
You can get them from UMI SLP or Kenny Brown (and most of the sponsors sell them, either 2 or 3 point)
they run up to $350 tho they can be had for less depending on what style (2 or 3 -point) or brand you want
You're better off with that even with a ram-air hood. The factory so-called ram-air isn't all it's crapped up to be. It actually down right sucks of you want a good ram-air setup. Go with a lid and FTRA.
Then again if you want to keep the stock tips... think about a cut out.
I started with a slp lid & lm2 catback... and it was enough of a change to make torque management a problem on my 1-2 shift (A4).
