should I spend $600 to fix my oil leak, or put that money towards a forged 346?
Alright guys, i need your opinion. I have an oil leak on my car due to some pore's in teh block from casting that are now leaking oil because of the higher volume of the ls6 pump, the car has 135k on it and it'll cost me $600 to get it fixed. Now i was wanting to get a rebuild next summer before i knew about this. Im going to start saving for a new motor, nothing crazy, i just want a forged 346 w/ls6 heads and a bigger cam then the 224, I figure it will take me about 10 months to have the money i need for this and to get the tranny upgraded too, (no laughing, im in school dang it!) Now the leak doesnt bother me, and in the end its only a leak. Now what would you guys do, spend the $600 to get the leak fixed and begin to save for the motor, or put the $600 toward the motor and live w/the leak. Do you think its possible that the problem can get worse? since there were bubbles in teh cast i dont see how it can, but i dont know (IMPORTANT POINT). It also does get on my o2's after awhile, but i dont mind spraying them down (externaly) w/carb cleaner to take care of it. What do you guys think?
Originally Posted by 2K2WS6TA
Well the $600 will buy alot of cleaner and O2s, so if you're going to replace the motor anyway, live with the leak (keep an eye on the oil level and the O2 condition) and start saving for the new motor
![Werd](https://ls1tech.com/forums/images/smilies2/werd.gif)
The engine is high miles... if it was lower miles it would be worth saving it but at 135k miles.... just save for the new engine and when you pull this one out, sell it and I'm positive someone will grab it up for a decent price
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Originally Posted by jrp
how did you determine the block was porous and that was the sole cause of the oil leak. thats first i've ever heard of this.
IMPORTANT QUESTION: Should i have them finish off the dyno tune? I dont see its possible to get worse since its a casting problem and i dont see how the pores can expand, i may be wrong, lt me know if i am. They suggested i hold off on the tune until i decide what tod o.
GM has been fighting this battle for a while. In some Cadillac's in the early 90's (I believe the Allante) they had an all aluminum v8, with displacement on demand technology. They were pretty much the early north star engines. They had the same problem with aluminum blocks, pourous, and oil leaks.
Originally Posted by SporkLover
It's one of those manufacturing processes that hadn't been completly refined by the time the engine made it into full production. The aluminum is more pourous than an iron block, and in certain areas the block was cast a little thin.... the combination of the two can cause a higher mileage motor to leak oil through the block.
Originally Posted by 98NBM_TransAm
Do you know what the owners of the earlier aluminum v8's did? I mean did GM fix it, or did they just live with it etc?
