will using 89 octane instead of 93 affect dyno??
Originally Posted by Patman
You probably lost about 3-4hp due to knock retard.
Hehe
![Tongue](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_tongue.gif)
Originally Posted by NHRAMAN
If u keep it under 3500 rpm with 87,there should not be a problem...that is what my mechanic/friend/race car owner/driver says...low rpm's have little or no affect on harming a OBDII equipped vehicle.
on a recent 3000 mile trip, 89 octane gave me the best MPG on an A4 with small mods (ssra,free mods, etc). 31.5 mpg
previous owner ran the car on 87 octane for over 2 years and 20k miles. the PCM got used to it and probably kept it at the low timing table. no noticeable knock during WOT. maybe a little if WOT uphill.
when i switched to 93 octane, there was an immediate loss in MPG. once the PCM got used to it...the MPG went back up a little, but not as good as 87 octane.
i'll be doing another 3000 mile trip w/i a week to confirm.
Originally Posted by davered00ss
You can get carbon build up even in coler weather using lower octane fuel. Good way to ruin an engine.
![Huh](https://ls1tech.com/forums/images/smilies/LS1Tech/huh.gif)
![Bulls#!t](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_bs.gif)
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
Guys why does GM have the PCM have high and low octane tables? Is it because they KNOW in certain parts of the US and other country's that cars with LS1's installed may never have the advantage of using 93+ octane?? No dought that timing is optimized with premium fuel but geez their is no way a tank(s) of mid grade is going to cause any long term effects
save 3 bucks chance blowing a 30,000 cars motor.... hey that makes perfect sence..
Original poster i am not bashing you... There is obiously still members on this board that think the pcm will save them because we all know these cars NEVER have any pcm troubles...
hey if the pcm starts retarding the timeing because of knock, guess what has to be happening already for this to happen?
and what do you call this knock boys and girls??? its call preignition or detonation....
Anyone here wanna tell me the exact amount of time your motor can detonate without causing any lasting effects???
thats right... nobody can... you know why??? because it all depends on 100000 x factors, it could damage it in less the then a second, it could hold out a long time.
ever play russian roulete?
its 3 bucks... check the cushons of your couch, you might find 3 bucks in change there.
but hey.... who cares... its just a car right?
but most of our cars are nortorious for knocking on 93 octane also.
the oldguy who sold me the car said that he's been running 87 octane for 20k miles with no problems. on my first full tank with 87 octane (from the previous owner), i was expecting lots of knocking. hardly any (except WOT uphill). the PCM was settled at the low timing tables.
then when i switched to 93 octane....performance gradually increased...so i guess the PCM was reverting back to the high timing tables.....after a few months of 93 octane....still some knocking (esp. WOT uphill...summertime=worse)...about the same as it was with 87 octane & low timing.
conclusion....most LS1s needs a dynotune to rid of most or all of the slight knocking (btw, i did all the wires, colder plugs, seafoam, etc....what helped most was setting the fan to come on earlier with HP Tuners)
