check engine light?
Old Jan 13, 2006 | 02:49 AM
CRAGER's Avatar
Administrator
Originally Posted by josh1107
ses light
Ok, that helps. The SES light is for your emissions.
Now, has the SES light came on since you started this thread? Or, does it come on for a systems test once in a while? If no, then I would for sure have somebody run a TECHII scan on it. Maybe it can see why it will not run a systems check for it on start up.
If it has not come on for a long time I would do what 2001NBMZ28 had mentioned:
Originally Posted by 2001NBMZ28
...If it's not coming on at all an easy way to see if the bulb is working is to pull the AIR PUMP fuse - won't hurt anything and the SES should come on after a couple cold starts, and go back off after some more starts after replacing the fuse.
Edit: In ACC none of mine illuminate.
Well actually, either way I would pop that fuse out and just test the light. The fuse is in the engine compartment, by the driver's headlight. Small one about 15 amp fuse.
Peace,
Craig.
Old Jan 13, 2006 | 05:13 AM
josh1107's Avatar
like kurt d said, he has the same thing, it sometimes comes on, sometimes doesnt. which is probably normal, but the emisions guy didnt know that and wouldve failed me even though its normal. yes it comes on about 50% of the time, whether its hot or cold.(owners manual says it should come on every time) im not worried about again for 2 more years.
thanks
josh
