what's the largest cam upgrade /stock torque converter
Originally Posted by idrivesh!t
damn i guess you dont get sarcasm
after a few years of thinking about cams &TC I've desided on the crane Boss 2. specs
216/224/551/551/115LSA with what crane recommends 2500 TC.install both at same time.
this is a daily driver and just an occasionly drag car actually I treat the streets as my own personal race track only when it's safe to which is'nt often.
OK now I'll expect most to respond with 224 cam as a minium, this is actually a radical cam making about 45-50 hp. match that with 3K min-3.5K TC won't the car be a dog before 3K RPM (around town)
You don't understand that a stall won't make the car a dog, a 224 isn't radical either. Just because the rated stall speed of a converter is 3500 rpm that doesnt mean the car is going to be a slouch under those rpm's.
You seem pretty set on doing this *** backwards, so have fun.
Originally Posted by badmfkr
catagory is new LS1
you should stay over in the 11sec section,
I've gotten lots of helpful sugestions here.
Thanks I guess
Thanks I guess
Tech Resident
thanks for most reponses here even though not one actually answered.the initial ?
You will not be able to drive the car safely.. There were times when my brakes could not even keep the car still and I had to throw it in neutral to keep from rear ending someone.
You are going to go spend alot of money on a cam and not get anything out of it.. Listen to us we have done this before and are trying to keep you from making a VERY VERY stupid decision..
#32
Originally Posted by Joel_SS
Dude you are putting the cart before the horse, trust me, from someone who has driven an A4 with a stock stall and aftermarket cam. I had a 226/234 112 cam with the stock stall.
#33
Unfortunately you are too hard headed and set in your plan. Maybe you are simply waiting for that one person who will tell you what you want to hear?
When you put the cam in before the converter and can't keep it from dying when you put it in gear, come to a stop, go slower rather than faster....whatever it is that happens don't blame anyone but yourself.
#35
The largerest cam i would reccomend for the stock converter is the stock cam. I do not feel that the stock converter takes full advantage of the stock cam. There, i answered your question. Any larger than stock (or an LS6 cam) and you are going to have MAJOR driveability issues.
#36
#37
see Guy's I've always had Manuale transmission cars so I really don't completely understand the concept of the TC.
I think the preverbal light went off with the last post.
OK thanks guys I can take a hint 1. pick a cam then use manufactors suggestion on TC
plan1. install both at same time
plan 2. install TC first. then cam.
I guess picking the right cam is the hard part.
Thanks for adviceing newbie
#38
#40
couple of quick ?s from newbie's first cam install
1.Valve are non adjusting don't worry about zero lash? This is for non LS1 cams right? Just torque rockers?
2.TDC mettod when valve drops to top of piston, what do'es this mean I'll just have to compress the spring that much more?
3. Locks the smaller end faces toward the cylinder head?
The locks the center of lock has a raised spot line this up with the crease in valve stem?
4.where to insert the screw driver in the flywheel to lock down the motor?
5.AC belt must have missed this part where it was removed?
6. Valve I'm assumming it can't be installed upside down?
7. I'm assumming the flat part of the titauim retainer faces up?
Sorry to sound so stupid.
Thanks
Thanks
