What should my next mod be?
I have a 1999 camaro z28 M6, i have pacesetter headers, 3" y-pipe goin into a borla exhaust, 4.10 gears, and i have grinded the throttle body to open the blade completely, i have AIR and EGR deleted also, i run nitto drag radials also, so what should my next mod be? My goal is to be in the 12's
I bet you can run in the 12's already... A 160* stat is cheap, dyno tune will add 20-30 hp if you're lucky. I added almost 30 hp with an off-the-shelf Predator tune. The LS6 intake will be best a best value mod that'll get you over the top for sure. An underdirve pulley fit's in the relatively cheap mods. Another ET helper is LCAs, which are pretty cheap and easy to do yourself.
