I just bought a used T/A
Originally Posted by orbee
Hi again I was not sure if I should start a new thread or keep all my questions in this thread ? But anyways I paid 504.00 for oil ,lube and filter , tranny flush plus filter change, fuel filter , differential oil change plus gasket , and a 29 point car inspection (joke) because on Sat I was driving then my low coolant light came on . I bought some dexcool and filled my radiator . But my purge tank was full , any suggestions . I will go tomorrow to flush my coolant. Is that common for the light to go on after a so called 29 point inspection ? Hoses look good. Thanks again . And where is the fuel filter located at ? Forgot the services @ Cormier Chevrolet in Carson , Ca hence the high as amount ![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Don't go to the stealership for service. If you're not up for it, ask friends family for recommendations on a good mechanic. Local stealership wanted ~ $600 to do a timing belt/water pump on a friends 4 banger. I steered her to a good mechanic who did it for $225, had it done b4 noon.
As for the low coolant light, those sensors are crappola, don't bother to replace it, just do what I did, disconnect it. It's located below the radiator cap.
The car has a 40 series Flowmaster and from what I have gathered around here the Flowmaster is not a good choice for these types of cars right ? I have always lived by them since all I have ever owned where Chevy full size trucks , so my question is what would be the LOUDEST muffler I could buy without gutting the cats ? I had a Super 40 on my crew cab and it sets alarms off every morning when I went to work
![Headbang](https://ls1tech.com/forums/images/smilies2/headbang.gif)
