New to the ls1 seen
engine
the engine and tranny work great.this car has been well mantained.it holds good oil pressure and has lots of power.i was going to get a 99 z28 with all the same stuff awhile back with 80,000 miles on it . this 98 pulls a good bit harder then that 99 did.this cars in top shape just begging to be modded.
No need to do hardened pushrods either, the stockers wont flex and screw up geometry unless you have a larger scale cam. If you do like a 23X/23X .6XX/6XX 110 type cam I'd do hardened push rods. But the thing with those pushrods is if you over rev it (dont think you cant either, I know of A4's that have bent valves from over reving it) and over reving it with hardned rods will bend the valves since the rods dont give, which requires head pulling to fix it, as opposed to putting another rod bolt in.
