roll racing
Originally Posted by The Great White Bat
im not new to the whole fbody thing. this is my second camaro. what i have is a 99 Z28 with 2.73 gears. the car is stock with low miles. i just put a whisper lid on it. what im wanting to do with the car is make it a roll racing car. im pretty much 1/4 mile guy so im not up on the role racing scene. i want to pretty much destroy everything on the road. im thinking about doing all the normal stuff like headers and dumped exhaust. i got the lid already. i put LCA and a tranny mount on it just because i had them. would an 04 ls6 cam be a wise choice for power. i know its alot of work but i think it might be a wise choice. also, what are good tires for roll racing? should i keep the cast iron drive shaft or find an alluminum one? any help would be nice. i am going to keep the tranny stock untill she goes.
good luck trying to destroy everything on the road.....thats not gonna happen..
Bolt ons, cam, spray, nice converter, and pull as much weight as you can while being comfortable with what's missing. An auto with a converter should be fine with some nice radials like gs-d3s, bfg kd's, or some nittos.
Originally Posted by TWS
If I were you I'd tell the locals that "roll racing is for ricers, meet me at the track".
Originally Posted by Camaro_SLP
That is correct.
Originally Posted by camaroextra
The GU5 and GU6 cars came with aluminum drive shafts (3.23 and 3.42)
the GU2's didnt (2.72)
Originally Posted by Trust
Care to explain why? I dont understand it, if the TC if physically smaller, and that is the only thing that has been changed, less rotational mass, would that not cause the car to be faster throughout the powerband?
I think it has something to do with the efficiency of the converter. A bigger (loose) converter is not as efficient at converting horsepower at higher RPMs as tighter converter, and as stated earlier in the thread from a roll racing is all about horsepower. Im not sure though, Im just trying to use what I know about converters to figure this out, so I may be wrong, hopefully someone will chime in with a bit more knowledge on the subject.
#32
#33
You've got the wrong trans to be real good "roll" racer regardless of what stall you choose. You want heads and a cam for power. Then you want gears. No ones beat me off a roll yet but it will happen. There ar faster cars out there, its all about money.
When I roll with someone I get my rpms right where I want them before signaling for the race. The its just hammer time. I like to be in 3rd gear at 60-70mph OR about (4k rpms). Traction isnt an issue with a roll unless we're rolling from 25-40 mph and the tire are cold. Rolling is all about being at the right rpm at the start. Having enough power to win is basic.
#34
That was the only thing I could think off, but surely STR makes up for that? Anybody with the knowledge?
STR plays a big roll but when stall speed raises im sure that the STR will raise also, so you still are going to have a big (loose) converter that is not as efficient as say a stocker, unless its possible to have a 4000 stall at a 1.4 or 1.6 STR, but have you ever heard of a stall speed with a STR that low?
#35
What I dont understand completely is that if the stock stall is what say 1600? It lets the motor stall up that high before engaging, the only difference between mine and that is the STR and about 1900 RPM's worth of stall, but after that 3500 shouldnt the connection between the motor and tranny be the same as after the stock 1600 stall speed is reached?
#36
um not at all the stall speed is just just a rough estimate of how high you can rev your motor in gear with the brakes applied it depends on how much power you have
but anyway there is always going to be more slippage involved with a smaller converter unless the converters are locked up. Take for example your car is floored and the motor is running 6000 rpm with the stock stall the input shaft on the tranny may be only turning 5500 rpm and with the higher stall converter aat the same rpm your input shaft on your tranny may be only turning 5000 rpm
the reason converters make you faster at the track is
1. the initial launch (more slippage = higher torque manipulation + get in power band earlier
2. when you shift you keep your motor closer in between your torque and horsepower peaks
on the top end that amount of slippage affects the efficiency of the drivetrain thus making you slower on top more slip = more heat = lost energy = wasted power
#39
