What has gone out in your F-Body?
Old 07-20-2006, 06:06 PM
  #61
AronZ28's Avatar
90k miles now, bought it with 42k.
Front Rotors warped at 60,000. Slider pins on front calipers seized as well.
Camshaft position sensor at 51k miles. Camshaft position sensor again at 55k miles, made the mechanic pay for his own labor and put a GM part in it(cause he didn't orginally even though I told him to).
Knock sensor at 88k.
Monsoon speakers blew up.
Pinion seal.
Power window motors are slowin down.
Bubbles on the roof.
Paint chipped off the leading edge of the hood, and this isn't the first Camaro I've seen like this.
Headlights turned yellow.
Its still been very reliable for me though.
Old 07-20-2006, 07:59 PM
  #62
PEWTER SS's Avatar
2002 SS
Mileage: 3,000
Never had to replace anything on it.
1993 Camaro base 3.4L
Mileage: 130,000
1) water pump (around 100,000)
2) battery at (around 60,000)
Everything else is ALL original. I consider the battery to be an expendable maintenance item. So basically after 130,000 miles only the water pump failed.
Please note that the normal wear & tear items have been replaced: tires, brakes, various bulbs, etc.
Car is all original and starts every morning for the past 13 years.
I never have anything wrong with my cars-my 1993 LT1 Z28 either. After several year of racing the only thing it need was an optispark and window track arm. All three 4 gen cars I have were bullet proof..espcially that LT1.
Only the liberal biased asswipes of Consumer Reports with their red and black dots have problems with GM cars.
Old 07-20-2006, 10:37 PM
  #63
cruz3's Avatar
2002 Z28. 55K miles, bought used so I have no idea what has died. It just killed the front yoke and U-joint. Gotta love the GM Certified Used program. I believe the power windows go out because the motors get overworked by going too far up. That could also be the source of the door bulging.
Old 07-23-2006, 01:50 PM
  #64
LS1T/A4's Avatar
98 Camaro Z28 @58100miles, just bought in April.
`Both front turn signal bulbs
`Alternator
`Pass window motor is slowing down.
Old 07-23-2006, 04:20 PM
  #65
black01_WS6's Avatar
99,xxx miles on her and have had to replace
rear end- posi went out stock
Battery
clutch
02 sensors
A/C recharge
multiple turn signal bulbs
I figure thats not to bad for how many miles I have on her.
Old 07-24-2006, 01:38 AM
  #66
00BlueTA's Avatar
00 TA 42xxx
2 driver window motors
1 pass window motor
1 turn signal
2 rear tires
other than that everything is original to the brake pads and wipers, and all work fine
Old 07-27-2006, 12:24 PM
  #67
Jolly's Avatar
2000SS currently at 39K and yes it is a garage queen.
1. Rotors at 12K;
2. Drivers side Cat went at 18K
3. Window on pass side
4. Battery never went out but did leak + side causing me to have to replace the cable. Never let the Delco's stay after they turn 4-5y/old
5. Front Monsoon speakers; After the second time I left them in so all can experience GM greatness
6. Roof is bubbled all to hell and ozzing out something from the holes; GM told me "tough luck" so I also am leaving this as is so all can experience GM in its greatness. GM shuold be completly embarrassed about this. If they had fixed it my next two cars might not had been Nissans.
7. Front window cracked down the middle after I shut the drivers door. Really hot day probably caused it. I used to live in south Texas.
8. Now oil consuption is just a complaint but not something we as customers should have to deal with, even if it is a minority of LS1's. To all who do not know this the VQ3.5 Maximas also have it. I have a 2003 and it does the same exact thing the LS1 does.
my day
Old 07-27-2006, 01:21 PM
  #68
highwaywonderland's Avatar
Power Antenna Motor-- 22000
Driver side window motor--- 22000
Old 07-30-2006, 10:16 PM
  #69
distortion_69's Avatar
Sold mine with like 103k.. Had basic stuff.. tires/brakes/alignment.
passenger side window motor.
Had a 1999:
At 20k power window motor and warped front rotors, at 30k tranny (lots of powershifting and launches on slicks).. That was about it, really.
Peace,
Josh
Old 08-01-2006, 11:06 AM
  #70
Flamin' bird's Avatar
2000 Formula 67k miles
Clutch (now going on second one) 1st at +65k now at 67k
Differential 67k (was going at 66k)
02 sensors (not replacing)gone back in 64k
Taillight (drivers side soon) 65k
Drivers Side Window Motor 65k (but was bad when I bought it at 30k and lasted till last year)
Passenger Side Window Motor (soon)
Headers (march 04...dont remember the miles)
Rotors (replaced with Eradispeeds...stock was fine in 2002)
Stock CD player 30k when I bought the car ( was under warranty)
