Why do stock LS1s run so hot?
Tech Resident
Originally Posted by Camaroz
My friend has a 99 Z28 and the temp gauge doesn't move at all. stays right at 210 Mine goes from 170-200 at most in heavy traffic on a hot day.
Originally Posted by ChocoTaco369
read above^^^. only 1998 temp gauges work. 1999-2002 gauges show a millimeter before 210* always unless it's cold or overheating.
Tech Resident
Originally Posted by TORCHD 02 TA
like i stated my 02 temp stays at 210. i was thinking of turning the fans to come on 190 - 200?? what do you say??
all i honestly see it doing is cutting your alternator's life. the only part of the car i'd invest better cooling in is the tranny.
it's up to you. i don't see a point. your engine was designed and tuned to run a certain way. i find things get messed up when you change them. generally, a stock car will outlast a modded car. things break when you mess with them. i see no point in changing it. it's not gonna do much if anything for you.
As far as the tranny goes, any additional cooling for the M6, or are you just talking about autos?
Tech Resident
Originally Posted by Shatterz
Yea, I think I'm gonna stick with the stock temps on my fans, I don't want to kill em and I'm never going to do that many mods.
the M6 is much stronger. they're as strong stock as a 4L60E is built. plus M6's do less work so i ASSUME they don't get as hot. that being said, a tranny cooler is less than $50. they can't hurt, only help so i say if you find your car on a lift sometime soon, you may as well put one on...
i'm no tranny expert. i'm just using my knowledge of science/physics here.
i'm scared of the 4L60E. it was in my V6 with 160hp. granted it'll take abuse all day every day, it's scary that it was put in a 160hp V8 in 1995 and STILL being used in a V8 with 350+hp in 2001. it just seems like it was built for something weaker.
The A4 is tough as hell!
yea you know what you make a valid point.. BTW what is your name?? the reason i was thinking of setting it a little cooler is b/c cars react a lot better to cooler weather, cooler air. so it would make sense. makes them run a littler richer that is why you get more HP.. but you are right it came from the factory to run at a specific temp.
#32
I wouldnt say that the car is designed to operate at a certain temperature. It's designed to operate under a temperature. The fans are there to keep the car from over heating, not to keep it cool.
But think about it logically, the cooler the car runs the better. Thats common knowledge, thats why you take your car to the track in November, chances are your ET is going to be better than when you take it in July.
I dont see how you would have any ill effects on the motor buy putting in a 160 thermostat. Only way I could see it being adverse would be if the stat stuck and the car overheated.
If you go by that train of though, your car was engineered to run with stock manifolds and exhaust, but does it run better with them as opposed to headers and aftermarket exhaust?
And also, for the most part, yes, a stock car will last longer than a modded car. But in general, a person that leaves their car stock, isnt as obsessed with speed as most of this board and wont beat their car up near as bad.
#34
Tech Resident
engines today like to run hot. they're tuned for efficiency, not raw power. that's why 160* t-stats are required when you run nitrous and FI and all that other good stuff. then you need your timing adjusted and you need a retune etc etc etc.....
it's better to leave your engine running the way it is. simple as that.
#35
Tech Resident
#36
the engine wasn't tuned to run at cool temperatures. the PCM is programmed for air/fuel ratios and all that. if the engine is running cooler, things get changed. that's why when you run a 160* thermostat, you should get it tuned properly. no matter what, your fuel economy gets cut and emissions go way up when you run cool.
They arent. I would say that perhaps a honda is tuned for efficiency, but you bought a performance car. You can say as much as you want about tuning and performance but numbers dont lie. Go run your car in 95 degree weather, then go run it in 45 degree weather and let us know which run turns out better.
Simple as that.
#37
Wow, hate to get into this again, but you're stating opinions as if they're facts.
Simple as that.
Simple as that.
#39
Simple as that.
Simple as that.
#40
Originally Posted by blkZ28spt
Do not confuse engine temperature with IAT (intake air temperature).
If you wanted to buy a LS1 car and leave it bone stock, you're pretty much on the wrong sight. For the most part, even the members with stock cars have aspirations of modding.
