Cheap Speed
Absolute minimum stall speed of 3,000. My personal recommendation is 3500 rpm minimum. It is the single biggest bang for your buck you will find. I don't count nitrous, per say, because it is only available for a relatively short period of time and 99% of your driving it'll do nothing but sit there.
Do some searching in the automatic transmission section to learn about converters.
What you should look into buying: Vigilante or Yank converter with stall speed of 3k-4k, B&M 24k gvwr trans cooler, tranny temp gauge, Trans go shift kit, subframe connectors and Nitto NT555-R drag radials (if it's a street car). You may or may not need 'basic' tuning of the shift points or torque management for it to run correctly.
It gets expensive quickly. All of those things could easily run $1,500-$2,000 or even more if you pay somebody to install them, depnding on what particular parts you choose.
i had been meaning the ask someone, what are the difference in sizes you get? thanks
The coolers are normally routed in line with the fluid that goes through the raditator, after the radiator and before going back to the transmission.
<-------- Whole new transmission and new to me rear end here.
1.64 60's will do that, I guess.
