re-ring or re-build kits
Originally Posted by Nemo02Z
Fort Hood Copperas Cove area
Id run a set of Mahle pistons and Manley H-beam rods 6.125".
Right there you will have right at 1200 or so in that. Then all new bearings, rings, and head gaskets will run you about 200 if you shop around. machine work shouldnt be more then 450ish. Spend the rest on whatever you wish. Hit me up if you need a good machine shop recommendation.
Now what if I just wanted to rebuild the motor the way it was, with the exception of new valves and springs, etc.... would the dealership be my best bet in locating new gaskets, bearings, seals......
