license plate cover. how to install?
Tech Resident
Originally Posted by Nickstock98t/a
hi do any of you know how to install the plate cover? thanks
https://ls1tech.com/forums/showthrea...hlight=torques
do torques make sounds?
do they? like i think mine does. i dont know but when i slowly accelerate fro 0-15 and release the pedal(and sometimes no release) i hear this thug or pop sound underneath my car. any idea to what this is guys? thanks
you're the FIRST PERSON EVER to make my sig. you're the man, keep on keepin' on.
^^that was was okay but i have to say this one is my favorite: https://ls1tech.com/forums/new-ls1-owners-newbie-tech/597403-my-trans-am-really-formula.html
Tech Resident
personally, i think he's screwing with us and these are all jokes. either way, they're pretty funny. or maybe he's a honda performance troll...although i think troll is a poor word choice here
no seriously guys. how do i install my license plate cover? the top two hook things that stick out go through, but then the bottoms dont latch. and there are no bottom two holes in the car... oh btw sorry i havent been posting threads and replying, i just moved homes and curently have not net access.
this is what i did. kept the plate bolted on. used velcro around outer edges of plate cover. with both pieces of velcro together put plate cover back in. then i removed cove again to make sure velcro tape adhered well to inside of the well for the plate cover. put cover back on, good to go. end result, if need to show plate occurs, plate cover comes off easily. plus its on pretty good so i dont have to worry aout it falling off. maybe this will help.......
#33
The front cover snaps right off. I recommend using a screw driver. Take the cover that guards the under carriage off. Get a nut behind there so you can fit the bolt through the nut. Then torque it to about 250 lb/ft. MAKE SURE IT IS 250 LB/FT! If you go anymore you might crack your bumper. If you did everything correctly you are LUCKY.
If it does not stay on you will have to remove the driver's side valve cover and take out the intake spring, valve, and pushrod from piston 7. You are going to have to remove the head to get the valve off. After that is done, spray the outside of your car with some acid. This will help the license plate stick on to it.
I hope this helps. It sure as hell worked for me. Oh yeah, one more thing!
VERY IMPORTANT: U.S. Law states that if you have a front license plate, you can only have three wheels/tires MAXIMUM on your vehicle. This can be up to a $50,000 fine.
I would recommend taking the front left wheel and tire off.
Phew! Almost forgot that.
#34
make sure you post pics with your finished results when you finally get the license plate cover on it would be greatley appreciated hahahahahahahahahahahahahaha i havent laughed that long in a really long time to hahahahahahaha o and make sure you put the clear side of the license plate cover to the license plate
#36
LMFAO!!!
Originally Posted by ChocoTaco369
you're my favorite guy on these boards. you're absolutely hilarious ever since this thread:
i never laughed so hard at a thread.
#37
Originally Posted by KameleonTransAm
Then tighten the screws on the flux capacitor
