Parts!
Hello, with in the next year or two i plan on getting the slp air lip, filter, ls6 intake (possible fast 90/90), cat-back or X pipe, then last, a stall. Question is, should i think about replacing my 10 bolt AFTER, or BEFORE? I dont plan on taking it to the track anytime soon, but i hope someday. Its also an a4. Lemme know
Thanks
Thanks
Being in the 11s have nothing to do with it. A full suspension car with slicks, some weight loss and minimal power gains could hit 11s, or a twin turbo street car running on street tires can do it, point being, some things are easier on the rear than others. The constant is that the rear sucks on stock power levels, if you can afford to do it before, I would. Specially because the stall that you get could compliment a different gear ratio ina built rear, -plus would wouldn't have to worry about it if you do it ahead of time.
Hmm... Maybe ill think about the rear then... I know if im goign to do the things to my car that i want to, then im going to need that rear eventually. But I figured i would be fine installing the other things first since i dont necciserrily take it to the track... ( hopefully one day ) Ill do some more read ups, and also, peoples info always helps =)
