o2 sensor ?
Old Dec 10, 2006 | 11:54 AM
bow125106's Avatar
Default o2 sensor ?
my ses light is on in my z28...autozone checked it...says bad o2 sensor..one in front of cat...ok, im about to change the o2 sensors,both of them up front...after this is done, when will my light go off....how do i go about getting it turned off..........
Old Dec 10, 2006 | 12:11 PM
staringback05's Avatar
once you change them, you can get it "cleared" and next time the car will come on it will register that theres not a issue anymore...
Old Dec 10, 2006 | 12:41 PM
bow125106's Avatar
Default ...
how do i get it cleared....can autozone do that
Old Dec 10, 2006 | 01:01 PM
any little scanner can clear a code....a tuning suite can delete them.....since youve fixed the problem all you need to do is clear it
Old Dec 10, 2006 | 04:09 PM
bow125106's Avatar
Default ..
so do u think the thing they have at autozone that reads codes can clear it..Also,,,after i put the o2 sensors in..the light will still be on....when i go to autozone should the o2 sensor code still show up or will it be gone and the light still be on til i have it cleared
Old Dec 10, 2006 | 04:24 PM
2001NBMZ28's Avatar
Depending on what the specific code is, SES will probably go off by itself after 3 consecutive starts (ignition cycles) without a failure, but remain stored in "history" for an additional 40 cycles. If you're worried about it being on you can reset the PCM manually to clear it after installing new sensors, but not necessary if it fixes the problem. Also if you have the code you can look it up at www.gearchatter.com for your year and it'll tell you how many failures until it comes on/goes off/what happens when lit, etc.
Old Dec 10, 2006 | 04:54 PM
rickyracer25's Avatar
yes the tool at autozone is capable of clearing the codes
Old Dec 10, 2006 | 05:17 PM
00formLs1's Avatar
not many autozones will clear codes anymore
Old Dec 10, 2006 | 06:43 PM
bring your crow bar with you....theyll clear it
Old Dec 13, 2006 | 02:16 PM
specops94's Avatar
Acutally, your SES light will not be on. The computer will continue to show that you had a problem in MEM but it will clear itself in about 100 miles. That is a built in safegaurd so that someone can't clear a problem when they pull up to the inspection station, and then drive off before the problem can resurface.
Either way, once you replace the O2 sensors (good deal on replacing both at the same time) the shop you take it to will clear it OR if you do it yourself, just about any autoshop can clear it. It becomes a question of whether or not they will be it is against many of their rules.
Not to worry. Be careful of screwing the threads if you do it yourself and good luck with the fronts, they are a bear!!
Mike
Old Dec 14, 2006 | 09:30 AM
Z28LS1camaroguy's Avatar
Yeah a guy at autozone told me that they dont normally or arent suppose to clear Oxygen sensor codes for some reason, but he did for me anyway since he knew me.
Old Dec 18, 2006 | 10:54 PM
WS6 Rampage's Avatar
From: The dirty taint of the country. ...Los Angeles
I guess its because allot of people just want the code cleared and think its fine after that so they keep driving on it and **** some **** up not too long after. They just don't want to be somehow responsible in any way for the problem get'n worse and then the blame being put on them somehow.
Old Dec 25, 2006 | 02:58 PM
transamhottie06's Avatar
I have a 98 trans am and i just replaced one of my o2 sensors and after you drive a couple of miles it should turn off by itself.
Old Dec 29, 2006 | 03:08 AM
KW4life06's Avatar
is this a common problem with ls1s? should i b worried? can they hurt ur performance if i still have stocks?
Old Dec 29, 2006 | 07:17 AM
Honda Hunter's Avatar
If you disconnect the neg side of the battery why doesnt it clear the codes?
Old Jan 18, 2007 | 10:34 AM
1FSTLS1's Avatar
Reading this thread I was looking for a spacific fuse to pull to clear the code. I put cut outs on my car and when opend SES came on. Texas speed told me the rear 02s were deleted??? ( assuming that is the reaseon for SES) Any who on my Toyota I can just pull a certain fuse to clear codes. Is there one on my Z28 or do I have to disconnect the battery. Also tried disconecting negitive terminal yesterday and SES was still on. Is it true you have to have it disconected for a certain time 30 sec or 5 mins???
Old Jan 19, 2007 | 07:29 PM
azceta's Avatar
you say that you have a cut out and the rear o2s are deleted? do you have the simulators for the o2s or are they tuned out. another thing noticed you have long tubes and a cut out so you need to have about 18 inches of pipe after the o2s to read corectly
Old Jan 20, 2007 | 06:19 AM
1FSTLS1's Avatar
I only have a few inches the cut outs are directly on the headers. The rear 02 were supposedly removed in the computer no sims.
