What plugs should I upgrade to?
Old 01-29-2007, 09:19 AM
01pewterbird's Avatar
^^pretty sure stock was NGK?
Old 01-29-2007, 09:37 AM
lsx24's Avatar
Originally Posted by erikthegoalie
TR55's come gapped @ .055" at least the last 5 sets I have had to buy were...
It all depends on power too...the more HP made, the smaller the gap gets..you will see a lot of guys switch to the colder plug, like the TR6 when they go heads/cam/N20/power adder
I currently am experimenting with TR55's gapped to .045".....they were not burning right at stock gap (.055) so I closed it a bit....mind you I am head/cam car...stock I ran reg TR55's out of the box..
I feel the best way to select plugs, is by reading this site, and testing different gaps yourself...removing plugs is not that hard....well except for #8
This may be a newb question, but how do you "gap" plugs? As far as I know spark plugs aren't "adjustable", so there's no setting on the actual plug themselves to set a "gap". Do you mean when you install them, or before you install them? How do you gap them? What tools would you use? Thanks for the info!
Old 01-29-2007, 11:00 AM
trbochv6's Avatar
When you say the TR55's are you talking about the standard or the GP, IX?
Old 01-29-2007, 06:58 PM
LS1Tech Administrator
RPM WS6's Avatar
Received 1,685 Likes on 1,207 Posts
The gap is the distance between the electrode ground strap and the center electrode. You can adjust the gap by either opening or closing this distance with a gapping tool. Then you can check the gap with a feeler gauge.
Old 01-30-2007, 12:30 AM
Ripper415's Avatar
what does making the gap closer together vs farther apart do? does it cause the car to run lean or rich? also, what's a good gap for tr55's with no cam or nitrous mods. just a few induction mods (lid, ported tb, ssra, etc)?
Old 01-31-2007, 12:17 AM
LS1Aggie09's Avatar
just got some NGK TR55's/MSD wires in from ws6store and im going to check the gap once i get a little 99 cent gapping tool from autozone tomorrow and ill let yall know what my set is gapped at. from what i have understood anywhere from a .05 to .06 is good on a LS1 and i don't understand why now a .044 would be ok on the same model number plug (3951)...can someone clarify this? Thanks -Karl
Old 01-31-2007, 01:54 AM
ls1chris's Avatar
i went with NGK tr 55s @.55 with msd wires but my car had 80k on it and wires was looking rough.so far i have no complainst about that plug and wire combo
Old 01-31-2007, 04:41 AM
Danger731's Avatar
I hope everyone checks the plug gap before installtion.
Old 01-31-2007, 02:46 PM
2001NBMZ28's Avatar
I sent NGK an email a few days ago asking if they changed the TR55 (3951) and why the gap is listed different now on their website. Here's their response: "The spark plug has not changed. TR55 will still be preset to .060. The reason for the change in recommended gap setting comes from a change at General Motors with the supplier for O.E. plugs. The new supplier builds the plugs to .044. We have changed our application data to match that of GM. If you have had good success at .060 install TR55 as it comes out of the box." So, someone buys the plugs, they're gapped at .060, look up the gap listed on their chart, see .044. Messed up if you ask me.
Old 01-31-2007, 03:06 PM
lsx24's Avatar
How you do "physically" adjust the gap? Is it on the plug itself? Sorry but I'm having a hard time visualizing gapping. I didn't know spark plugs were adjustable (if they are adjusted on the plug itself).
Old 01-31-2007, 03:24 PM
RPM WS6's Avatar
That's kinda what I figured, however it's odd that they would pick .044 to recommend, since the new Delco iridium plug comes gapped at .040 according to the info I've seen from GM. I have yet to buy the new plug though, so maybe it is .044. But I'm certain that someone had a link posted on here to GM docs stating that the new plug for the LS1 motors was to be gapped at .040.
Old 01-31-2007, 03:26 PM
  #32
RPM WS6's Avatar
To adjust the gap, you have to bend the ground strap closer or further (up or down) from the center electrode.
Old 01-31-2007, 03:32 PM
  #33
lsx24's Avatar
Is the ground strap brittle and/or thin? Where is it located? I'm picturing the metal that "comes over" the tip of a spark plug, and that thing would be hard as hell to bend!
Old 01-31-2007, 03:36 PM
  #34
RPM WS6's Avatar
That's the ground strap. Beleive it or not, it really isn't hard to bend with a gapping tool.
Old 01-31-2007, 03:42 PM
  #35
2001NBMZ28's Avatar
I double checked the email they sent me, does say .044, but maybe a typeo on their part? Notice they didn't specifically say to regap (their unchanged plug) to .044?
Old 02-02-2007, 06:25 PM
  #36
CJDZ24_Z28's Avatar
NGK's are great plugs but i refuse to use them cause they are made in Japan. Go with AC delco irridiums
Old 03-30-2007, 10:16 AM
  #37
Intragration's Avatar
Sweet...couldn't agree more
Old 03-30-2007, 10:26 AM
  #38
99HorseSlayer's Avatar
iridiums ix's and superconductors do me just fine
Old 03-30-2007, 12:12 PM
  #39
98ws61le's Avatar
41-985 Spark Plug, Iridium
Gap .040 Do Not Deviate From Preset Gap .040"
