Did a burnout tonight and...
#45
Originally Posted by orangefun
correct me if i am worng, but wouldn't a spun bearing cause the oil pressure to be crappy? like really low, anyway after driving the crap out of my car it started sounding like it had a S/C on it, but it was just the lid not all the way on, so go figure.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#47
its Not a freaken spun bearing...spun bearings make a Knocking sound, not a friggen ticking...besides your oil pressure would be next to nothing....
your belts will squeek alot...its the most common. If it doesnt affect performance and driving, its nothing major and i wouldnt worry too much about it....could also be a brake pad rubbing the rotor from holding the brakes. The calipers on our cars are famous for locking up.
#48
Originally Posted by BLKWS.6
Idler pully bearings?
I'd be willing to bet it's the Idler Pulley Bearing. If it was the Power Steering, he would have mentioned the wheel getting hard to turn when the whinning starts.
Can't really explain why only after the burnout, but I bet it only happens when you first start the car and then slowly quiets down. That's the first sign of it taking a ****, replace it as soon as you can.
#49
I don't see how a burnout could cause you to spin a bearing unless you were holding it to redline for a long time. i have done my fair share of hell raising burnouts. I wasted two full tread goodyear gator back tires one time in a single burnout and my car is still running just fine. I have never held the rpm's up really high during a burnout though, i just let it shift out and hold her steady. I have been on the rev limiter many times and now that I have Heads and a cam I shift out at 7,000...............Either my car was damn good wednesday made car or there was something wrong with a person's car before to spin a bearing during a burnout.
#52
Originally Posted by slick1851
I have a not to car savy friend who had 20k on his WS6, and did a burnout.....
I wasnt there for it but, some how the rod went out the block with a hole in it lol
Not to sure what the hell he was doing
![Cry](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cry.gif)
#54
Well, it wasn't power steering. I checked the fluid, also my belts. It's still making a whine until it shifts around 35. Performance doesn't seem to be affected. The sound is just annoying.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
#55
Originally Posted by thosewhohatedmecreat
Wow. people are still trying to say spun bearing? take the belt off ur engine, start it, see if it makesthat noise.. u can run it for a lil on just ur bat ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
but it was just the belt and a bad idler pully..so check those
#56
first of all thanks for all replies guys. I did the burnout for about 10-15 seconds and it held on 6,000 rpms for about 3 seconds. I think the idler pulley is what is making the noise.
#58
are you sure it's under the hood? if you can't hear it while it is just sitting there in idle it could be the rear. i had that problem when i was driving thought it was coming from the engine but it ended up being the rear about to go. but if it is doing it while at a stop then i'd check the idler pulley
#59
Originally Posted by bene
It's your power steering pump failing. Get ready to replace it.
my supra did the same thing after i did a burn out. im not sur ewhy but mine went away after afew minutes.
im not familiar with the genIV style power steering but i know my PS pump became starved for fluid and got very loud for a short time.
